Trillium Rear Window Missing - Fiberglass RV
Old 03-17-2007, 10:29 AM   #1
Trailer: Trillium 4500
Trillium Owners,
Our trailer had the rear escape window removed and an A/C installed in its place. We want to return it to the original configuration.Could someone eyeball the frame for dimensions and to see if it is the same profile as the crank out windows. Do the latches work on the vertical or horizontal plane?
Thanks Dave
David Schroeder is offline   Reply With Quote
Old 03-17-2007, 12:45 PM   #2
Bill F.'s Avatar
Trailer: 92 Bigfoot 13.5 ft / 05 Freestar
Trillium Owners,
Thanks Dave
Hi Dave,
It looks like the same profile pivoting on the same hole position as the top pane on the other side. I've attached some photos of the hinge and latch details. There is a triangular shaped casting right near the hinge that I first thought was the hinge. I didn't figure out what it's purpose was. The width is identical to the other side and height is equal to 3 panes on the other side. If you need more info let me know.
Bill
[attachment=8599:att
achment]
[attachment=8602
attachment]
Bill F. is offline   Reply With Quote
Old 03-17-2007, 01:30 PM   #3
Bill,
Thankyou very much for the info and pics, they are exactly the info I need. I don't think I'll be able to duplicate the latches, but the triangular hinges, (I do think thats what they are) are still mounted to the frame. I think they have stops built in to limit the opening to just past 90 degrees. Thanks again Bill, Dave.
PS: I did get your address and will price shipping on Monday. I'll probably call you to confirm as they are quite heavy (#'s= $$$). I'll open them up to inspect and let you know the condition also.
trillium
Wanted: 1984 Trillium Rear Emergency Window Jessie, K Classified Archives 0 05-31-2010 08:22 PM
Replacing rear window Sandra Lair Problem Solving | Owners Helping Owners 1 05-08-2010 08:27 AM
1971 Trillium Rear Window Cracked...help me... Paul Richter Problem Solving | Owners Helping Owners 8 08-11-2009 05:35 PM
Rear Jacks - Am I missing a part? Sheryl M Problem Solving | Owners Helping Owners 15 10-17-2007 10:01 AM
Rear window Replacement Legacy Posts Problem Solving | Owners Helping Owners 3 11-08-2002 07:43 PM
