I have a 1974 Trillium 1300... the roof vent needs to be replaced.... it appears to be pop rivited to the roof. Can anyone advise how to remove the inside ceiling facia (trim)... it seems to be glued with the lip under the soft ceiling material.
Not sure how yours is, but when I removed mine, the whole thing came out through the top. There was no trim that I can think of.
awsome... thanks for that info... now I can drill out the rivets without worry... the replacement I bought has an outsid peice and and inside trim... did u rivet yours back in?
Yes I did rivet it back in. Used the rubberized butyl tape as a gasket, then ran a bead of RV Pro Flex (think that is what it was called) around the end as well.
