Trillium Top Bunk Safety Rail - Fiberglass RV
Old 08-26-2013, 08:23 AM   #1
Our 1976 Trillium has a fold-up top bunk under the front window. We'd like to take our two grandkids camping. There are brackets on the wall on either end, rather like the brackets at each end of a shower curtain rail, that I am told are meant to hold a safety rail to help prevent the sleeper from rolling out. Does anyone know where I might get one? Has anyone found a safe substitute or other option to make the top bunk safe?
Randy J. is offline   Reply With Quote
Old 08-26-2013, 09:07 AM   #2
Trailer: 1976 13' trillium
If you follow this link
Our '76 Trillium finally done!
and scroll down the page you should see a solution I have come up with. Works great and my five year old and three year old have both never had an issue.
chris loewen is offline   Reply With Quote
Old 08-26-2013, 09:45 AM   #3
Thanks Chris. I'll check out Home Depot.
Old 08-26-2013, 07:10 PM   #4
Randy if you have a liquidation world near you they have a assortment of compression shower rods that work perfect for 10 bucks make sure you get the longer one
Mikmay is offline   Reply With Quote
Old 08-26-2013, 07:30 PM   #5
Trailer: 1980Trillium 1300
...For your reference, mine is...heavy-duty, extensive reinforced, copper rails. Both have thick mattresses. Each bed has it's own reading light and 120VAC/12VDC outlet for games, ipad, laptop....Upper bunk could handle...175lbs...
Old 09-10-2013, 03:05 AM   #6
Trailer: Shopping
Nova Scotia
Excellent job. I love the bunk bed option as we have young kids, but have some reservations about the safety of the default setups. I assume a similar arrangement could be fashioned for other eggs with a similar bunk setup.
Troy
Dreamcatcher is offline   Reply With Quote
Old 03-14-2016, 02:16 PM   #7
Trailer: trillium
New Brunswick
Hi Randy ,Chris is right about the safety rail, my rail is spring loaded and fits into a shower curtain bracket at each side of the trailer walls. 2 screws hold the bracket in place. That is factory so far as I know. Duane
getaway1 is offline   Reply With Quote
Old 03-14-2016, 03:16 PM   #8
David Tilston's Avatar
Mikes solution is as close to factory as possible. A telescoping pole with a spring inside with rubber ends. The pole in the factory solution pulls apart for easy storage.
trillium
bunk rail greendragon Problem Solving | Owners Helping Owners 9 06-24-2013 09:56 AM
Bunk Bed Safety Rail - Commercial Options? Sheri N. Problem Solving | Owners Helping Owners 5 05-14-2011 06:42 AM
Front top bunk on Trillium 4500 James Cooke Care and Feeding of Molded Fiberglass Trailers 3 05-13-2010 11:15 AM
Top Bunk Safety Net / Feature for 13" Camper Carl G Modifications, Alterations and Updates 7 03-29-2009 10:09 PM
Safety bar for top bunk bed Rob Carmody Problem Solving | Owners Helping Owners 4 06-02-2008 10:22 AM
