Trillium trim - Fiberglass RV
Old 03-13-2012, 05:46 PM   #1
Trailer: Trillium 1300
Trillium trim
Don't know what it's called, but it's like trim that covers seams along the inside of the trillium. It's all wrinkled and bunched up. Is this normal and if not any suguestions on how to repair. Again, thanks for your imput. Shelley
Shelley Brinacombe is offline   Reply With Quote
Old 03-13-2012, 06:00 PM   #2
Shelley, it's called seam tape and it appears what you are experiencing is fairly common. Some owners have carefully pulled the tape off, put it in a pan of hot water and reapplied (with caulk) by stretching it carefully. A Trillium owner should probably give you step-by-step instructions.
Others, have removed the seam tape completely and filled the gap with caulk. Using a damp, scrunched up paper towel you could then apply "texture." Others just smoothed the caulk completely.
I like this treatment, after caulking the seams, hide them with paint! FINALLY... I made peace with my seams!
Here's some more links: help with seams
Old 03-13-2012, 07:41 PM   #3
Chris McVeigh's Avatar
Trailer: 1978 Trillium 4500
Nova Scotia
Trilliums have their interior seams covered with a t-molding that can shrink over time. Usually it can be heated / stretched and snapped back into its track. Check to see if the track needs to be reglued in place.
Chris McVeigh is offline   Reply With Quote
Old 03-13-2012, 10:10 PM   #4
Roy in TO's Avatar
Shelly,
If you have the T-molding type that Chris suggested. If you have wrinkling, chances are, you will see a peice of track at the end of one of your pieces of trim.
Some owners have found that by removing the offending piece (gently pull it out of the track from one end) and putting it into a bucket or sink of hot water and then reinstalling the trim you can get rid of the wrinkles.
And yes, this is normal.
Old 03-14-2012, 07:56 AM   #5
Trailer: 1984 13' UHaul
Louisiana
If it's a small area, a hair drier may work.
itlives is offline   Reply With Quote
trillium
1971 Trillium Trim around the door Paul Richter Problem Solving | Owners Helping Owners 9 10-20-2010 07:38 AM
No trim used Perry Mac Donald Problem Solving | Owners Helping Owners 0 05-01-2010 08:06 PM
Trillium trim Alistair Camelford Care and Feeding of Molded Fiberglass Trailers 0 06-25-2009 08:35 AM
Trillium Bellyband Molding/Trim TorreyT Problem Solving | Owners Helping Owners 2 04-23-2007 04:21 PM
Trillium Trim d_wildemann Care and Feeding of Molded Fiberglass Trailers 2 09-06-2006 04:59 PM
