TrIlLiUm TrUnK? - Page 2 - Fiberglass RV
Old 07-09-2007, 01:06 PM   #15
Trailer: 2005 13 ft Trillium Outback
Veiw from off to the side to give perspective
So, with the 30 inches in the from and the 4 plus feet in the back, my 13 footer has grown to a 20 footer. Talk about two footitus.
When and if you add a cargo carrier to the rear of the trillium, you should consider mounting the carrier using one of these Hi-Lo hitch. These should be bolted in snuggly to reduce movement.
Curt
2005 Trillium Outback w/ 30" tongue extension
1989 Award 730, 30'
2003 PT Cruiser
1998 K2500 Chevy Silverado 6.5 Turbo Diesel, 4X4, ext cab, short bed
Curtis F. is offline   Reply With Quote
Old 07-09-2007, 07:51 PM   #16
Kevin Woods's Avatar
Trailer: Former 1978 Trillium 4500 owner
Attachment 8793
Curt
Awesome, this is exactly what I am wondering about. It probably is not do-able but I would love to carry a scooter (Vespa 230Lbs) on my rear carrier.
K
Kevin Woods is offline   Reply With Quote
Old 11-05-2008, 04:27 PM   #17
Sorry for the long delay in replying. Been away from the forum. My extension works well for me. With out a counter weight on the back end it will be very tongue heavy. In excess of 500 pounds if they build it with substancial materials. I have about 300 pounds on the rear with the cargo box and the rack that supports it. That gives me between 250 and 350 pounds tongue weight. When I am going any distance I have a 3/4 ton pickup with a Equalizer brand hitch. Rides beautifully with that configuration. When I have gone on trips of less than 50 miles I have towed slowly with my PT Cruiser. I do not advise anyone to do that. I consider myself a skilled driver and am familiar with the local roads.
I like the 30" by 60" platform in front. It carries my 4 wheel handicapped scooter just fine. I should have made it 32" but it works as is.
Even with the equalizer hitch there can be some up and down movement of the tongue on rough roads. With the PT on local roads, I have to be very aware of any conditions that would cause the tongue to oscilate up and down. there is a lot of weight far away from the wheels, so any up or down motion has a lot of mass in motion.
The Outback is very finely balanced on the wheels and care must be taken when adding weight front or rear. Add more than a couple hundres pounds (100 Kilo) to rear only and there won't be enough tongue weight. Add more than a couple hundred pounds to front only and there will be too much tongue weight.
My biggest regret is not getting an air conditioner. Second biggest regret is now shower.
I also raised my trailer 3" and changed the axel to 3,500 pound capacity. I also upgraded my tires to load range D. With the additions front and rear, I was right at the limits for tires and axel. Reason for the 3 inch raise was for ground clearance front and rear because with the extended length, the trailer would scrape the rear or drag the tongue on some drive entrances.
I didn't know all of that when I started the process. I now have a 21 foot trailer with a 10 foot living area, registered as a 13 foot trailer.
1989 Award 730, 30'
2003 PT Cruiser
trillium
OH | 1981 Trillium 1300 Trade for a Trillium 4500 Gene Griffin Classified Archives 13 03-06-2011 07:27 AM
1976 13' Trillium and 1980 Trillium 5500 18' Jenn Classified Archives 10 05-19-2010 02:36 PM
newbie confused..which trillium to buy,,Outback (canada) or Trillium u lloyd cicetti General Chat 17 08-04-2008 07:46 PM
Trunk Monkey Nancy in Oregon Jokes, Stories & Tall Tales 4 12-29-2005 12:33 AM
