Trillium water tank drain - Fiberglass RV
Old 10-12-2007, 09:26 PM   #1
John Perry's Avatar
Trailer: 1996 13 ft Scamp
Send a message via AIM to John Perry
I have just aquired a 1979 Trillium Jubilee Model in excellant condition. It is like the front bunk 4500 model.
I cannot find the drain valve for the water tank.
I have looked under the trailer and under the seats. There are no access plates or openings into the area under the floor where the tank is.
Any help would be appreciated.
John
John Perry is offline   Reply With Quote
Old 10-15-2007, 03:50 AM   #2
Joe MacDonald's Avatar
fresh or black water? my 1300 didn't have a drain on the fresh, my 5500 has a drain on the end of the tank inside the trailer
Old 10-15-2007, 08:37 AM   #3
John Perry's Avatar
It's the fresh water tank. I guess it does not have a drain.
Thanks Joe
Old 10-15-2007, 04:05 PM   #4
I had a 74 Trillium before I got my Casita. It had a water tank under the seat on the driver's side. The drain was at the far end of the tank, near the rear wall. I ran a line from this drain, leaving it open, and added a new drain on the frame exterior. This was much easier to use.
-Don
d_wildemann is offline   Reply With Quote
Old 10-15-2007, 06:32 PM   #5
Trailer: Trillium 4500
The tank on my 4500 is inside, under the table/bunk. There is a about a six inch piece of plywood hinged to give access to the inside. The drain is on the right side (looking at the back of the trailer) very near the front of the tank. It should have a drain through the floor. As I remember the vave was hard to work. Be careful not to break it out of the tank.
Dan M. is offline   Reply With Quote
Old 10-15-2007, 08:59 PM   #6
Trailer: Trillium 13 ft 1976
John
i have a 13ft 1976'er. My water tank is under the dinette seat on the 'passenger' side. the vlalve shut off should be on the left hand side. had to replace as brittle and wouldn't turn. didn't cost much. have a look under the trailer around this area. should have a rubber hose there that empties it. hope this helps. maybe yours needs replacing if you cant see it
Janet G is offline   Reply With Quote
trillium
plastic knob to drain water tank rotted again Karalyn Plumbing | Systems and Fixtures 18 05-14-2013 06:21 AM
Water tank drain Lee Hillsgrove Problem Solving | Owners Helping Owners 3 07-01-2007 08:41 PM
Gray Tank Drain Legacy Posts Care and Feeding of Molded Fiberglass Trailers 9 06-08-2003 06:50 AM
