Trillium window removal - Page 2 - Fiberglass RV
Old 07-08-2015, 06:55 AM   #15
Alex C's Avatar
Window Moldings
Originally Posted by David Tilston View Post
They can be found here:
Hehr Screw Cover, Molding
Thanks a Ton. Just what I was looking for.
Alex C is offline   Reply With Quote
Old 07-11-2015, 04:34 AM   #16
Trailer: trillium
New Brunswick
Hi Alex, I have just re-done all the windows in my 13 ' Trillium. If your windows are the jalousie type they should just pull out once "all" the screws are out. It is easy to miss one. The old butyl is likely stuck to both surfaces. The ensolite is glued to 3/4" plywood strips bevelled 45 deg away from the window opening. It is not glued to the window itself. You must be careful cutting the contact cement away from the ensolite. I used a dull edge putty knife as my wood was damp from leaks. Once you see the strips you will have a better idea what I'm talking about. The newer trailers have a different style sliding window. I don't have any experience with those "yet". Re-sealing the windows solved the leaks in my Trillium. Took about 2 days for all 4 windows. Buy some caulk tubes of no-more nails glue to fasten the esolite around the edges again.Get the water clean up type. Much easier ! Believe me ! Good luck with this. It will take some time but it's not that difficult. Don't skimp on the butyl sealer when you put the windows back in, "more is better" in this job !
Duane
getaway1 is offline   Reply With Quote
trillium
Trillium Window Removal David Swinnard Problem Solving | Owners Helping Owners 77 09-05-2016 07:25 PM
Trillium 1300 furnace removal... David Swinnard Problem Solving | Owners Helping Owners 7 11-28-2015 11:37 AM
Trillium belly band rivet removal Mike and Sarah K Problem Solving | Owners Helping Owners 14 02-24-2010 02:20 PM
Need Help with Carpet Removal on Trillium Jola & Liz S Care and Feeding of Molded Fiberglass Trailers 4 06-21-2009 01:17 PM
rear window removal Trill 4500 ryan a Problem Solving | Owners Helping Owners 3 10-09-2008 10:02 AM
