Trillium window shade - rusted shut? - Fiberglass RV
Old 05-09-2006, 04:49 PM   #1
WendyM's Avatar
Trailer: Trillium 13 ft
I picked up this Trillium a few months ago and am working on getting it ready for our first outing! However, there is a shade covering the front window (the bunkbed end) that is supposed to pop up and I cant seem to figure it out!
When I pull out from the bottom, it gives but it appears that it might be locked down by either 2 bolts on each side - (pic shows one bolt with nut and one without):
Or by a wingnut on each side:
In both cases I have remove the nuts and have just the end of the bolt sticking out - which Im afraid to mess with too much in case they fall inside. And Im afraid to pull on it much harder in case I break something.
I am unable to access it from the inside since the window is in the way and doesnt open enough to even see whats going on in there.
I'm stumped... ...any suggestions?
WendyM is offline   Reply With Quote
Old 05-09-2006, 05:37 PM   #2
Alistair Camelford's Avatar
Trailer: Trillium 13 ft 1973
Wendy, the wing nut when loosened, allows the bolt to be pushed in and release an aluminum "V" catch. If the bolt is rusty, spray some rust-spray or WD40 and let it sit for a while. Then put the wing nuts back on just at the end of the bolt and push in . You might have to push the gravel guard in towards the trailer to aid in releasing the catch. Good luck....Alistair
Alistair Camelford is offline   Reply With Quote
Old 05-10-2006, 09:37 AM   #3
WendyM's Avatar
It worked!
Your info and alot of WD40 made it happen!!!
THANK YOU Alistair!!!
trillium
Rusted Screws amado_aguilar Problem Solving | Owners Helping Owners 3 07-20-2008 08:12 AM
Keeping Door shut while traveling? Trillium 4500 Fred G. Problem Solving | Owners Helping Owners 14 03-18-2007 08:58 AM
Awning -- Shade Pete Dumbleton Problem Solving | Owners Helping Owners 0 07-22-2006 03:42 PM
Egg in Shade II Legacy Posts Modifications, Alterations and Updates 11 08-22-2003 01:19 PM
Privacy Shade Legacy Posts Modifications, Alterations and Updates 16 07-03-2003 12:16 PM
