Old 07-20-2012, 05:29 PM   #15
Thomas G.'s Avatar
Trailer: UHaul CT13 TV: Escape Hybrid
SE Michigan
Originally Posted by Alex C View Post
I have to let you know that I completely rewired the Trillium. I put in a new Converter, new Battery and new Distribution Center. I'll draw up what I have done and post it. Maybe then you will have a better idea what I did and did not do right.
Yea, sounds like a polarity is reversed some where.
Just call me Tom.
Old 07-23-2012, 04:06 PM   #16
Alex C's Avatar
Trailer: 1977 Trillium 4500
I have drawn up what I have done to the wiring of the trailer. When the Shore Power and Tow Vehicle are plugged in at the same time you will see that I blow 2 fuses and one of the fuse holder and wires. If you have any suggestions I will gladly accept them. NOW if I can only figure out how to insert a image?
Name:	<a title=Trillium Wiring Renovation.jpg Views: 30 Size: 162.5 KB ID: 49161" style="margin: 2px" />
Alex C is offline   Reply With Quote
Old 07-23-2012, 06:00 PM   #17
Thomas G.'s Avatar
SE Michigan
Alex,
When you say two fuses blow, do you mean the one at the tip of the red arrow and the circled one? These are in series.
Does this happen only when the refrigerator is running on 12 volts?
Just call me Tom.
Old 07-23-2012, 08:16 PM   #18
Roy in TO's Avatar
What size are the 2 fuses that keep blowing?
What new converter did you put in?
What do you have on the TV end of the 12V? A solenoid, isolator or circuitbreaker?
Old 07-23-2012, 09:44 PM   #19
Trailer: 2006 Scamp 13'
Attachment 49161
The converter is attempting to charge your battery and/or provide some of the cranking power to start the tow vehicle. Simple answer like if it hurts when you do that, don't do it. If the fuses blow when shore power and the tow are connected don't connect them both at the same time.
Old 07-24-2012, 07:13 AM   #20
Alex C's Avatar
Yes, the fuses indicated by the read circle and arrow. When the Frig is on 12V both fuses (circled 10ams and arrow 5amps) blow but the 10am fuse and holder burns up. When the Frig is NOT running only the 5amp fuse blows.
Old 07-24-2012, 07:16 AM   #21
Alex C's Avatar
The fuses are 5amp and the distrabution center and 10 amp at the other end of the 12v wire. I do not have a TV or isalator. The converter is a 50amp WFC that I got from a 33ft 5th Wheel trailer. The gentleman was upgrading to a 80amp converter.
Old 07-24-2012, 07:19 AM   #22
Alex C's Avatar
I know what your saying but it happens usually by mistake. My daughter forgot to take off the tow vehicle plug because she did not need the tow vehicle while in the campground. I blew a fuse trying to test the light and also forgot to disconnect the tow vehicle plug thus blowing the 5amp fuse with the frig off.
Old 07-24-2012, 07:27 AM   #23
Thomas G.'s Avatar
SE Michigan
I know what your saying but it happens usually by mistake. .....
I think Byron is correct - the tow vehicle (TV) is drawing power off the trailer when starting. The solution is either a relay wired so that it only contacts when the engine is running or an solid state isolator (not preferred due to voltage drop).
Amazon.com: Stinger 80 Amp Battery Relay Isolator: Automotive
Wire it to a circuit that is only hot when the ignition is on - like the radio.
Just call me Tom.
Old 07-24-2012, 07:32 AM   #24
Alex C's Avatar
By the way Roy, I see that Princess Auto has put the LED Tail Lights on Sale again at $39.00. I'll be going down there on Tuesday to pickup a set.
I went to Princess Auto today (July 24, 2012) and purchased the LED trailer lights that are on sale for $39.99 regularly $79.99. Now the real task begins. Now that it is not too hot I will work on it today. I noticed that the small LED lights are still not on sale. So, Roy you will have to wait a little longer to put them next the the larger LED tail lights.
Old 07-24-2012, 07:48 AM   #25
Roy in TO's Avatar
Alex,
The 2 fuses that keep blowing are the only fuses between all 3 sources of power.
The manual for the Dometic RM211 says the fridge needs a 10 amp fuse and nothing else should be connected to that circuit.
What about putting a breaker / fuse on the 12V side from your TV (you should have something there anyways) and moving the connection to the line directly feeding the battery?
Old 07-24-2012, 04:03 PM   #26
Alex C's Avatar
Attachment 49161
I have found a questionable wire route that troubles me so I changed some of the wiring. Let me know if you agree or disagree. I have removed one of the fuses and holder and run the tow vehicle power wire to the supply of the distribution center.
Old 07-24-2012, 04:51 PM   #27
That's more typical. You might want to consider changing the 30amp fuse to 20 amp. If you're concerned about that measure the current with the stuff you would normally have on, on.
Old 07-24-2012, 04:53 PM   #28
AKSCAMP's Avatar
Trailer: 1975 Scamp- Super Cozy Ambulatory Mega Party, 1980 Boler B1500 15'
Alaska
Thanks for the wiring diagram there. I have to completely rewire my Scamp and I'm having to learn the why and where of isolaters, converters, inverters, etc. Hopefully it helps me once I'm under way.
AKSCAMP is offline   Reply With Quote
trillium
wiring trillium lights burns Problem Solving -- Owners Helping Owners 11 07-25-2012 06:26 PM
1977 Trillium - Wiring to a 4 Plug gblacketor Problem Solving -- Owners Helping Owners 13 04-09-2012 04:48 PM
HELP- - Re-wiring a 74 Trillium 13' Barry Konkin Problem Solving -- Owners Helping Owners 17 04-16-2009 11:20 AM
Vehicle wiring to tow Trillium 13 francene Towing, Hitching, Axles and Running Gear 9 03-19-2009 09:14 PM
Wanted:Trillium wiring diagram Mikey Problem Solving -- Owners Helping Owners 1 09-01-2007 05:07 PM
the next 365 days.
Our Communities
» More about our Communities
Automotive Communities
Marine Communities
Close [X]
