trouble finding low toxin camper - Page 2 - Fiberglass RV
Old 07-04-2016, 09:22 PM   #15
Trailer: in the market
How about a cargo trailer then line it with materials you like and equip it with furnishings which are not offensive to you? you could even install HEPA filters on the the vents and run a roof fan to insure clean air.
Floyd, do you mean like a box truck, or a cargo trailer that is being sold as a camper, and that has been plumbed and wired?
I don't want to do plumbing and wiring.
I knew I could rely on the folks in this forum!!
Margaret
Lonely Road is offline   Reply With Quote
Old 07-04-2016, 09:33 PM   #16
Originally Posted by charlsara View Post
Here is what the factory website says.
Our cabinets are built to last! There is absolutely NO particle/pressed board used in our construction what-so-ever. All of our cabinets are made of quality Red Oak and sealed with two coats of Valspar water resistant lacquer and two coats of Valspar water resistant sealer.
Notice it says Red Oak but does not say solid wood. I have taken some of mine apart to build my side dinette. The cabinet face under the couch and the face piece under the bed is 1/2 oak plywood. The sides of the upper cabinets are the same. The doors and the stiles and rails are solid oak. This is better construction than sawn lumber because the ply will not warp. However is does contain glue. Even if it were solid wood the planks would have to be glued together. I don't think you will find any campers that contain wood that doesn't have some glue.
I think you're right. There probably isn't a camper that doesn't contain plywood! So, my choices are . . . either sealing the whole thing with a non off gassing sealer, or, going out West . . . .
Old 07-04-2016, 09:44 PM   #17
The LiL Snoozy people will sell you a shell. Then you could have the interior built the way you want. I considered doing this. They priced it about half the price of the completed unit. My wife said if I did that we would never go camping. The build
would be fairly easy because the LS furniture is not required to stiffen the body as some others are.
Now that's an interesting idea!
What about plumbing and wiring?
Margaret
Old 07-05-2016, 12:10 AM   #18
Borrego Dave's Avatar
Trailer: Casita SD17 2006
Originally Posted by Lonely Road View Post
Hang on here a sec., bpfick and others:
Check out these links:
My Chemical-Free House: Trailers for the Chemically Sensitive
For this one, you have to scroll down to "trailers," which is the word Canadians use for "campers.
Here's another link:
Search for the Cure: My Healing Journey: Safe and mobile housing
I need to leave my house and my neighborhood because of toxicity and possibly mold. I need to find the "right" place to live. What else am I to do?
Off gassing solves a lot of problems, so I'm hoping I might be able to find an "egg" type camper out West somewhere.
Margaret
Kind of have to agree with bpfick but on a little different tack. My wife lived in NC for many years and mold and such was typical just because of the everyday weather and east coast location. Many people have moved from cold, wet and humid climates for asthma relief with many successes....I'm one too. Moving to a different climate may reduce your overall sensitivity. Just a thought, good luck to you.
Borrego Dave is online now   Reply With Quote
Old 07-05-2016, 09:54 AM   #19
low toxin camper
if you do a search you might find a NOS Camplite trailer which would be all aluminum...I've seen several 11F models...
RV Rabbit is offline   Reply With Quote
Old 07-05-2016, 10:23 AM   #20
Ed Harris's Avatar
Margaret
I have just built a cargo trailer into an RV from scratch starting with the raw already built cargo trailer and RV'd it up the way I wanted exactly.
I have no idea about your threshold for the various materials and how you might tolerate certain items but I do know that you could sure build one from scratch exactly the way you want and need it to be.
When I mean you I mean either you or an experienced builder or manufacturer.
Many of the better companies will indeed custom build to order and roll one for you as you think you want and need.
Mine was Steel,Aluminum and Plywood when I got it and it would be pretty simple top replace the Plywood if needed or somehow seal it to your needs even.
You can also get an interior this way that has only what you need and nothing that you don't.
There are adhesives commonly used in these cargo rigs that you might not realize are used too but they can sure do it another way if that is what you want?
I like Pro Line Trailers in N.H. as an example of a smaller custom builder that would make it the way you want.
Look them up and give them a call,I have and was surprised and excited at the willingness they have to make it my way!
Listen to Floyd,He knows things!
Ed Harris is online now   Reply With Quote
Old 07-05-2016, 10:40 AM   #21
charlsara's Avatar
Trailer: 2014 Lil Snoozy
Thank you for that, Charlsara,
How long did it take for the smell to wear off?
Do you like the camper?
Margaret
It took a couple of months for the smell to go away when it was closed for long periods. When it did smell we opened it up and it was OK after a few minutes.
We do love the camper. I have done several mods to make it "ours" but it is a fine camper from the factory.
If you want to PM me. We can let you look at it. We are in SW North Carolina so we may be fairly close to you.
Old 07-05-2016, 10:43 AM   #22
charlsara's Avatar
Margaret
I believe they said it could be built to any stage you like.
Old 07-05-2016, 12:18 PM   #23
Trailer: 2010 Escape 17B
I am pretty sensitive to the off gassing though nothing like you. We had a Scamp that was two years old and it was still off gassing majorly.
I don't envy your task as unless you are building from scratch I think unfortunately it will be like looking for the proverbial needle in the haystack.
With the carpet on the walls in the Casita I just cannot see that working at all, like you say maybe an older trailer with the full fiberglass inside.
Good luck, hope you find what you need.
kootenaigirl is offline   Reply With Quote
Old 07-10-2016, 06:18 AM   #24
Kai in Seattle's Avatar
Now we're getting somewhere! What about doors? Bathroom door?
Is the couch vinyl, and if so, can it be custom made into something else?
Did yours off gas much when new?
Sorry about all the questions.
Margaret
You can remove the bathroom door and replace it with a large towel on a solid metal tube rod, hung with screws and stainless washers. Use metal clip rings available at fabric stores and many other places. If you use a washed cotton "bath sheet" or beach towel, it's big enough, and there should be no toxicity. Also--probably lighter anyway, can be used to dry yourself (and will then just dry out while hanging), easily removed and washed, etc.
Also--marine grade ply sites we found in Seattle made a point of stating that they no longer use formaldehyde in their glue formulation. It's not necessarily an industry standard any more--easily checked at each source. We had our three sheets of 5/8" marine grade plywood drying in our living room for months over last winter before work on our 1973 amerigo (filled with mold and rot) had progressed to the point where we finally used them...I'm highly sensitive to mold and chemicals, and other than the smell of fresh wood, I experienced NO reactions to those three sheets.
Semper ubi sub ubi.
Old 07-10-2016, 08:04 AM   #25
Trailer: '84 Scamp 13' & 2001 Casita 17' Spirit Deluxe
Arkansas
I can't really imagine what it must be like to have your problems Margaret. Our youngest great grandaughter was born with mild food allergies & her parents go to great lengths to accommodate her special needs, but nothing like what you have described. I've no recommendations for you, never having experienced what you describe. I do hope you're able to find a rig that will suit your requirements & are able to 'get on the road.' Best of luck to you!
Harvey is offline   Reply With Quote
Looking for camper low in toxins and/or sufficiently off gassed Lonely Road Wanted: Molded Fiberglass Travel Trailers 11 07-05-2016 12:28 PM
NH Motor Vehicle is having trouble telling me if my camper needs inspection lpk49 Care and Feeding of Molded Fiberglass Trailers 28 06-18-2013 12:57 PM
Searching for lite low priced camper. J.S.Lahm Wanted: Molded Fiberglass Travel Trailers 0 04-15-2008 07:36 AM
Finding a product for a backsplash Gigi Problem Solving | Owners Helping Owners 20 04-30-2006 08:34 AM
We need help finding a Microwave!!! Legacy Posts Problem Solving | Owners Helping Owners 6 02-05-2003 03:45 AM
