Truck rail spacer - Fiberglass RV
Old 01-31-2018, 01:31 PM   #1
Raz
Raz's Avatar
Truck rail spacer
My new Frontier came with a spoiler attached to the tail gate. It sits about 1/4 - 1/2 inch higher than the top of the bed rails. I need a spacer to increase the rail height so my tonneau cover frame is level. I've seen several installations in parking lots but nobody around to ask. While I can use wood, I wonder what others have used to solve this problem. Raz
Old 01-31-2018, 01:54 PM   #2
SteveV's Avatar
Trailer: Amerigo FG-16
This might be a good place to use some plastic composite deck material. I don't know if it's offered in that size but you should be able to cut it down on a table saw fairly easily.
SteveV is offline   Reply With Quote
Old 01-31-2018, 02:47 PM   #3
Look at the link below, It shows several different gasket materials for toppers , one of them may be appropriate.
https://www.amazon.com/Super-Cap-Sea.../dp/B00BNGBXOC
Old 02-01-2018, 12:05 PM   #4
Might be able to take the spoiler off and use a flat cap from a standard model or earlier model truck.
Old 02-01-2018, 02:39 PM   #5
Raz
Raz's Avatar
That's plan B. About $60 oem.. But I'd hate to lose the mileage improvement the spoiler provides.
Old 02-01-2018, 05:58 PM   #6
Borrego Dave's Avatar
Raz, if it's a straight change out fit, maybe someone with the other type would swap with you....so they can get the better MPGs and look cool .
Old 02-02-2018, 02:50 PM   #7
Raz
Raz's Avatar
Maybe they'll buy my bridge too. . Actually, next time I'm in Home Depot I'm going to check out SteveV's suggestion.
Old 02-02-2018, 09:51 PM   #8
Trailer: Trails West
When you put on a tonneau cover you don't need the spoiler because the cover will provide more mileage improvement than that spoiler can. The spoiler will only provide a very minimal gain if any, not worth the trouble of keeping it. Spoiler becomes basically another thing that can get damaged when loading and unloading items from the back of the truck.
You have to remember that between the tonneau cover and hauling a trailer you will have no idea of what has happened to your airstream other than it has been majorly disrupted by the trailer. Which is why the concept of the spoiler saving you any gas is pretty much a shoulder shrug.
Old 02-03-2018, 07:16 AM   #9
I'm quite sure he knows that, and the remark about mileage was sarcastic. He was rolling on the floor laughing!
The issue is if you remove it, you probably have to put something else in its place. On many newer models it's like Swiss cheese underneath, not clean, painted metal. The generic, stick-on caps people install to protect plain metal tailgates don't fit, either.
They call it "progress"...
Axle spacer Herman M Parker Modifications, Alterations and Updates 15 09-29-2013 05:18 PM
Fiberglass spacer Rick kl Problem Solving | Owners Helping Owners 11 06-25-2013 07:50 PM
Fantastic Fan spacer installation on top of a Boler kevin61 Modifications, Alterations and Updates 1 07-05-2009 05:55 PM
Scamp 5th wheel truck bed and rail height Rhys H Towing, Hitching, Axles and Running Gear 4 07-18-2008 10:55 AM
Scamp 5th wheel truck bed and rail height Rhys H Problem Solving | Owners Helping Owners 0 01-01-1970 12:00 AM
