TV mounted - vibration - Page 3 - Fiberglass RV
Old 08-08-2013, 08:04 PM   #41
Trailer: asdf
Alabama
The problem here is that there is an optimum viewing distance for any monitor size / resolution / font size. Take a 32" monitor and view it from 2' away and it is almost unusable, just too big! Take a 19" screen and push it back to the back edge of the desk and it is almost unusable, too small.
On my computer table I use two 23" monitors, about 30" from my face. They are 1920 x 1080 pixels native and they are just "perfect" for me, at that distance. I use one application on each monitor, and I wish I had 4 of them. Two "will do".
Now take those same monitors, mount them on the wall (or in the corner as you see in the pictures in these RVs. Sit on the couch on the opposite of the table and tell me what you see when used as a computer monitor? Teeny tiny little print that is unreadable from that distance. They may be fine as a "TV" viewing a movie but that is not what I need.
Now... with a browser (as I discovered awhile back) hit Ctl+ and the screen magically zooms bigger. Cool. Except you get less lines on the screen but a usable as a "kludge", when browsing the web. However that doesn't work with anything else. So when I am writing C# code in visual studio... or using SSMS to create a query, it is back to useless.
Now, replace that 23" monitor with a 32" TV, hanging on the wall just exactly where the 23" was a few minutes ago. What do you see?
Probably darned close to what you would with the 23" monitor 30" from my face. Perfect.
Further to this discussion, WHY I need it simply isn't the point. All of that explanation didn't help in the slightest in determining how to mount it or how to relieve the stress or how much stress to expect, or how much current it will need or anything else that is the actual point here.
The point is that I need to hang a 32" (or thereabouts) TV on one wall of the TT. I may in fact mount two of them if I can figure out how. It will almost certainly cover the window on that side and... I don't care.
Expanding the thread to discuss how the electronics of a TV will interface to a computer is most relevant (to me).
jwcolby54 is offline   Reply With Quote
Old 08-08-2013, 08:33 PM   #42
Trailer: asdf
Alabama
So this is an example:
Amazon.com: Samsung UN32EH5000 32-Inch 1080p 60Hz LED HDTV (Black): Televisions & Video
1080P LED. The TV weighs 13 lbs without the stand, of course I would replace the stand with something equally heavy I assume.
Still, 13 lbs for the TV itself is pretty amazing it seems.
Old 08-09-2013, 04:48 AM   #43
Ed Harris's Avatar
Pretty much exactly what I have said too.
Everyone that I know that does what you do uses multiple smaller monitors for exactly the reasons you already do.
As I also have already said,waiting until you are sitting in your trailer to make these decisions is simply prudent from my experience and again I install these sets every day.
It also sounds like you have not yet tried this idea of yours on a bigger display?
I have 2 24" Dell IPS monitors sitting on my desk and right next to them is a 24" Samsung 1080P TV set that I can easily compare directly to the monitors.
As you point out they can each "Zoom" to be readable at some level but as I said and you added the pixel structure is clearly not similar at all. The TV output at these views is almost unreadable though in theory it sounds like a good idea.
Why not just buy a 32" computer Monitor and call it a day?
Well if you can,do!
The cutoff seems to be 27" and for practical reasons. Though the sets these days are for all intents multi scan monitors anyway a lot more goes into them than just the spec.
I like the 27" Samsung and they are at Sams Club for under $250.00 all the time. The problem though is that most 24" monitors look a lot better to most people in real world use.
The 27" Apple is amazing but 3 times the price,worth it but I would not put one in a trailer.
Then the cost and weight just goes through the roof as you look to anything bigger.
So a TV seems a natural alternative and for browsing and graphics they are fine. For text and DB work they fall flat and can be unusable.
A friend who is a Web Developer recently picked up a 32" Samsung TV as I suggested it as a TV,he didn't mention it would sit on his desk for work.
He ended up getting rid of it a week later and I found him 2 23" Apples instead and he could not be happier.
These sets are just not what they seem always.
I have a feeling you will realize as I already know that using a single big monitor will just not work as well as a few smaller ones in a tiny space like this.
On the other hand you seem clearly determined to do this the way you state now so good luck with your search.
As has been stated already,the sets do not have a lot in them anymore and are both cheaply made lightweight devices and have little inside for inertia to play with as long as securely mounted to the trailer.
I know that the better name brands may be made to a higher standard but they may also may not be and I would guess that they are more alike than different in construction these days?
Also light might be better but I really don't think it will be a big deal with a solid mounting platform.
Backlight methods seem to have no part in toughness or reliability either and I would not qualify a purchase based on this either way.
If you do need that much TV and mount it in place I would look to mount it top and bottom in there and not just suspended from a Vesa mount bolt pattern. I would give it better support than that. I would also look inside and see exactly how it is constructed before attempting to decide how to mount it taking into account where the weight and mounting points are and if they seem reinforced or not.
A lot of these units have the mount location in odd spots that makes me wonder how they ever decided where and how to locate them?
I installed 3 32" units Yesterday where the Vesa mount location caused the TV to See-Saw on the wall if you looked at them wrong? I need them to articulate from the wall and had to use much heavier duty mounts than usual for the weight as the mount location just was not good for a stable install without an overkill mount. This of course can create its own problems too.
Friends of mine modify TVs for use in Prisons and they open and modify every single one for strength and to try to prevent them from being "Removed" from the mounts. There is not a lot of anything solid to work with there.
Also I mainly use a 17" High Res Macbook Pro about 1' from my face for all the reasons I mentioned earlier which you then seemed to echo.
Just the post practical solution I have found in the confines of the Egg.
It is a simple matter to hang a swing away platform or tray for the machine and then get it directly in front of me when needed and push it away when not.
Hope this had risen to a level that you find helpful in some way at last.
Old 08-09-2013, 06:37 AM   #44
Trailer: Class A Motorhome
Clip: "Expanding the thread to discuss how the electronics of a TV will interface to a computer is most relevant (to me)."
And exactly what part of the FGRV would this pertain to?
There are lots of sites dealing with computer questions where the Sheldons & Wallowitzes of the world love to show off their expertise (as well as control the discussions)
BTW: Our Haire 24" flat screen not only works on 12 VDC, it is a 1080 resolution. Can't say that Sam's Club would be my first choice when looking for a quality flat screen, or at least I wouldn't give up looking for one just because SC doesn't have same.
Old 08-09-2013, 07:30 AM   #45
Kevin K's Avatar
Trailer: 1983 13 ft Scamp
I mounted a Insignia 19" to the corner shelf of my trailer.(99 Casita)
Picked it up at Bestbuy as a open box item for $62.00
Old 08-09-2013, 08:26 AM   #46
rabbit's Avatar
Trailer: '98 BURRO 17WB
Delaware
Might be a good time to remind all that the measure of relevance on FGRV is what you bring to a discussion that other members find useful, amusing, or just "Oh so true." The passionate commitment of experts and specialists is welcome as is the innocent enthusiasm of generalists. Mutual tolerance is the ingredient in the mix that assures that owners are helped and problems are solved. 'Nuf said.
jack
Old 08-09-2013, 09:11 AM   #47
Ed Harris's Avatar
Point taken Jack.
Just trying to help but.....
Old 08-09-2013, 09:36 AM   #48
rabbit's Avatar
Delaware
Not pointing fingers. You went the extra mile, Ed. Appreciate your effort to keep this hard-mouthed hobby horse in the middle of the street.
jack
Old 08-09-2013, 09:58 AM   #49
Spanke's Avatar
Trailer: 1978 Trillium 1300
Cumberland, Indiana
jack
Spanke
Trilliums Rock!
Old 08-09-2013, 10:08 AM   #50
Ed Harris's Avatar
Originally Posted by Bob Miller View Post
Clip:
Bob
Sams is the best place to find one almost all the time!
If they have what you are looking for the price is always better and the performance plan they sell is also better than everyone else's.
I always look to Sams first and that is for over 100 TVs a year.
Tip#2-Sears!
I try to buy only Panasonic and Samsung as they are just the best built and have fewer problems for me than the others and both Sams and Sears have great pricing on both brands.
Oddly though the stores do not all carry the same models so it pays to go and look in person often.
So since Sams does carry a High Res.Samsung 27" computer Monitor and it is a screaming deal price I point to that!
Ed
Old 08-09-2013, 10:31 AM   #51
Steve L.'s Avatar
jack
That may be where you're taking the site these days but, just from my own personal perspective, I'd like to see posts directed to molded fiberglass trailers at least tangentally. No cause to be rude (not you) but a little focus couldn't hurt, General Chat topics aside.
Old 08-09-2013, 10:36 AM   #52
[QUOTE=Ed Harris;409400]Bob
Just to mention, at Sam's, as at Wal-Mart, it's all about exact model numbers. I have often found differences in seemingly identical TV's and other products at both Sam's and W-M. They buy enough to force manufacturers to shave every penny off that they can, and that sometimes means a lesser quality product with a slightly different model number.
Soooo, when you read a review about that new product you want, be sure to follow the model numbers, not the Brand and Model names.
When I had to return a flatscreen TV to Sam's, that was DOA out of the box, a couple of years back,, it took an act of the stores general manager to approve the return as well as a 30 minute interrogation and inspection of the product. At COSTCO returns are a 3 minute transaction and the customers are always right.
Old 08-09-2013, 10:51 AM   #53
rabbit's Avatar
Delaware
Oh so true, Steve. Thank you.
jack
Old 08-09-2013, 11:04 AM   #54
Steve L.'s Avatar
jack
I get it. And I mean this in the nicest possible way and tongue-in-cheek (figuratively):
Old 08-09-2013, 11:18 AM   #55
Trailer: asdf
Alabama
Ed, I'm not committed to a TV, in fact I absolutely understand and appreciate the hesitation in using one as a computer monitor.
I do strongly desire a 32" (or thereabouts) size for the reasons stated. I haven't looked for computer monitors in the 32" size. I just assumed that they either wouldn't exist or they would be astronomically expensive.
Old 08-09-2013, 12:21 PM   #56
tartosuc's Avatar
Trailer: 2007 uhaul ct13
Quebec
you are correct,
they are almost non existant in that size.
that said if you stick with samsung, panasonic, nec, sharp you can get a good quality tv with computer inputs, our most trouble free at work are the samsungs...
pretty much every other brand will be similar tv rebranded or with different model number depending on where its sold at.
tartosuc is offline   Reply With Quote
Old 08-16-2013, 08:08 PM   #57
The point is that I need to hang a 32" (or thereabouts) TV on one wall of the TT. I may in fact mount two of them if I can figure out how. It will almost certainly cover the window on that side and... I don't care.<_<
Hey, I just measured my 32" LCD TV. It measures about 18" top to bottom. How about hanging it sideways on the cabinet with a hanger designed to jackknife down into position.
Or even easier, hinge it the opposite of mine and swing it out of the way against the wall when not in use. It may obscure part of a window.
You could mount it to a piano hinge above a window or to the ceiling and swing it down when needed.
The how is simple.... a nice piece of oak or a length of square tubing, firmly attached through the hull then attach the hinge and attachment plate to that.
Old 08-21-2013, 09:15 PM   #58
Trailer: asdf
Alabama
After a bit of research I purchased a Samsung 32UE5000 from Sears where they had it in stock. $350 after tax. Computer monitors this size are in the $1000 range.
For those who care, Google TV 4:4:4 which will bring you to an arcane discussion of signal processing to reduce bandwidth which also wreaks havoc on sharpness when used as a computer display. It seems you need (prefer) a 4:4:4 mode which is an end run around this signal processing specifically for use as a computer monitor.
In any event this Samsung provides this mode and so I bought it. It is a gorgeous display as a monitor.
A 32" TV is large but not as large as you might think. 1080P provides me with as high as 1920 x 1080 resolution which is way north of the native resolution of my laptop, but is the exact native resolution of my 23" desktop monitor. The NVidia chipset and Windows 7 just picked it up and recognized it. I did have to "pair" the HDMI 1 input with the PC input type to allow selecting all of the various available resolutions in the PC end. Prior to doing that it showed only my native laptop resolution (1400x900 IIRC).
Leaned against the wall and then sitting with my back against the opposite wall of my scamp, 1920x1080 is still to small to be generally usable. However the resolution steps down nicely and I am currently using 1600 x 900 which is just about right for text resolution in text editors and the like.
I don't have any video ATM so I can't discuss using the set as a TV though most reviewers love the set. As I mentioned, I am not much for TV in general.
And I have not figured out mounting yet but the set is very light, just under 13 lbs so hanging it shouldn't cause issues.
According to the tag on the back the power consumption is 52 W and a "typical" rating of 33 watts (whatever typical might mean). I have a Killowatt meter which I will use to measure actual power consumption one of these days.
I have only had it on for an hour so take it with a grain of salt but so far I am impressed. It appears to fit my requirements of light, fairly low power, big enough to hang on the wall, and nice sharp text and graphics when used with a computer when viewed from across the trailer.
Brake Controller mounted in trailer???? Michael Pupeza Towing, Hitching, Axles and Running Gear 18 05-07-2012 12:58 PM
Got the 19" TV Mounted and closet sorted out Carol H Modifications, Alterations and Updates 14 09-16-2010 11:20 AM
Roof Mounted A/C Units Butch H Care and Feeding of Molded Fiberglass Trailers 3 03-25-2007 03:09 AM
Where are yours mounted??? Isaac M Problem Solving | Owners Helping Owners 7 01-04-2007 05:20 AM
Roof vs. Front Mounted AC Legacy Posts Care and Feeding of Molded Fiberglass Trailers 15 10-20-2002 09:41 PM
