TV vibration causing doggy fears & big woes for us! - Page 3 - Fiberglass RV
Old 05-10-2015, 02:43 PM   #29
I can’t add much more to the fine suggestions already given but I can offer some encouragement. My dog would stress out really bad in the car and trips were so miserable that I finally got some sedation from the vet. I hated to use it because it pretty much knocked her out for 8 hours and it took her a while to wake up fully, but it had to be done at the time. She was really bad in the crate so I usually didn't use it. Instead I tied her to the seat she could touch me but not interfere with my driving. It was not as safe for her as it would have been in a crate, but it had to be done.
But as time went on, she got better. Especially on interstates where the motion and noise was steady. One reason I bought a Sienna was to be able to use the crate on the floor, and for some reason she did not object to it and now rides pretty well. She still gets overly excited when I slow down (thinking “we’re HERE! I guess) but all in all she is a pretty good traveler now, and the sedation has not been used in a few years.
After I got a new HVAC system in the house, she had similar panic episodes when the fan kicked on. I am guessing because it sounded like rain, and rain means thunderstorm in her world. T-storms are still the worst for her. However, as time went on (only a month this time) she adjusted to the fan noise and not does not even flinch when it comes on.
So hang in there! I would try some of the remedies suggested here and also get some sedation from the vet to be used only if needed. Not taking the trailer is not much of a long term solution either
As for the towing, I think you might be pushing things with the Sienna, even if you are well under 3500 lbs. I have a 2015 Sienna and a 16 foot Scamp on order, so hope the lighter Scamp is OK with it, but I know the Sienna is far from a great TV. Perhaps some sort of towing expert in your area can inspect your setup? Also, I wonder if you know someone with a beefier TV who could drag your trailer while you sit in the car with the pooch, and see if that helps.
Old 05-10-2015, 03:24 PM   #30
Trailer: 17 ft Casita Liberty Deluxe
The van does feels every bump, curve, swerve, and vibration in the trailer. ...
We are facing having to take this trip without the trailer if we can not find a solution and wonder if there might be a better hitching system, or some way to resolve the vibrations, etc. Has anyone else had this problem, do people think it is the tow vehicle/trailer combo creating the vibrations, etc.
I do think it is quite possibly the tv/trailer combo is the problem. For one thing it sounds like this began with the Sienna, not the Previa. The other thing is that you should not feel every bump, etc, as you say. To me, it sounds like a scary way to travel. It's quite possible you are carrying a bigger load than your van's suspension system can handle. BTW, our first tow vehicle was a Previa and we noticed quite a difference when we changed to a 4-Runner. In our case the Previa was a marginal tow vehicle for our 17' Casita and upgrading the tow vehicle made our travels far more enjoyable.
Otherwise, see if your trailer is level when loaded and if the load is balanced? If the trailer is "tail heavy" it can oscillate back and forth and if the hitch is too heavy, it can lighten the load on the van's front wheels (which can cause problems with steering and braking). You could try rearranging the load in the trailer to see if that makes a difference. And I think it would be a good idea to weigh your rig when it is loaded for a trip to see if your trailer & van are within all the recommended maximum weight limits.
I hope some of the suggestions for Abby work for her and for you.
Carol Christensen is offline   Reply With Quote
Generator vibration on a Scamp trailer? mgully Modifications, Alterations and Updates 11 02-19-2015 10:22 AM
TV mounted - vibration jwcolby54 Problem Solving | Owners Helping Owners 57 08-21-2013 09:15 PM
Insulation re-do & adhesive woes - what could we have done differe Michael M Problem Solving | Owners Helping Owners 11 02-01-2009 09:08 AM
a Doggy Merry Xmas! Gina D. Jokes, Stories & Tall Tales 6 12-29-2008 12:57 PM
Doggy/kitty Portch Coach George Jessup Modifications, Alterations and Updates 0 04-30-2006 11:29 AM
