Two-burner stove cover? - Fiberglass RV
Old 05-20-2011, 08:29 PM   #1
Bobbie Mayer's Avatar
Trailer: 2011 Escape 15A
I tried a search but can't figure out how not to get every instance of the word Stove.
Is there a stove cover I can buy somewhere? Or an easy plan to make one to cover a two-burner gas stove?
Old 05-20-2011, 11:22 PM   #2
Joy A's Avatar
I made one out of wood. 1" x 2" for frame with a piece of 1/2" plywood for the top. I made the frame 3 sided so I could use the cover as a lap table. I like to have things multi-purpose.
I put cover on the floor while traveling. When I use the stove I put the cover over a small folding cabinet extension I have on the bed side of the kitchen cabinet, making the usable surface larger.
Joy A. & Lily
and "Puff", too
No. Ca. Sierra Foothills
Old 05-21-2011, 06:03 AM   #3
Mark J's Avatar
Trailer: 13 ft Scamp 1999
Great idea- I've been thinking about a cover for our stove as well but like that you can use it for other things too.
What do your cabinet extensions look like/are they made out of wood/screwed to the sink cabinet?
Mark J is offline   Reply With Quote
Old 05-21-2011, 09:17 AM   #4
Trailer: Escape 17
stove cover
We didn't want another folding metal top for our two burner stove top so I bought a wooden cutting board from one of the hardware stores. The board was just large enough so that I could attach four legs made from a 1" wood dowel and I used four rubber cane feet on the dowels. The legs are just long enough to clear the burners and close enough to slip over the stove snugly. The cutting board gives more counter space when not using the stove and setting anywhere else also gives more counter space. I tried to glue the legs to the board but they came off so I drilled a center hole in the leg and screwed them to the board. When we switched trailers and went to a three burner stove the top still works setting across the stove. Hope this helps,
Jack of Tucson
Jack Allen is offline   Reply With Quote
Old 05-21-2011, 09:41 AM   #5
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
1"x2" for sides
1/8" wood top
Covered with Formica
Name:	May 19 2011 007.jpg
Old 05-21-2011, 10:21 AM   #6
Joy A's Avatar
The cabinet extension is 2 folding arms screwed to the cabinet with a small wood cutting board attached.
Joy A. & Lily
and "Puff", too
Old 05-21-2011, 10:28 AM   #7
Greg H's Avatar
Trailer: 72 Boler American
Indiana
I'm thinking of re purposing the piece of counter top cutout for the sink in the house.
Old 05-23-2011, 03:38 PM   #8
Trailer: 1985 16 ft Scamp
Ohio
I am planning on using an inverted aluminum cookie sheet. That is if I don't remove the cook-top entirely. If you wanted to get tricky, install it with a couple of small hinges so it stays put, and you have a built in splatter shield.
BigMike is offline   Reply With Quote
Old 05-23-2011, 09:12 PM   #9
Trailer: Uhaul CT-13
Ohio
I used a 17" Stainless steel baking pan. It stays in place fine during travel.
Panoz77 is offline   Reply With Quote
Old 05-24-2011, 10:54 AM   #10
Greg H's Avatar
Indiana
Now that's cool, and CHEAP.
Old 05-24-2011, 01:33 PM   #11
Ohio
That is exactly what I had envisioned. I love the great minds on this forum!
Old 05-27-2011, 02:02 PM   #12
Great ideas, thanks, everyone!
hood for 2 burner stove Cyndivg11 Problem Solving | Owners Helping Owners 21 02-19-2012 01:20 PM
Would you want a three burner stove? Raz General Chat 31 03-03-2011 06:48 PM
Need 2 burner stove D Martin Problem Solving | Owners Helping Owners 2 12-14-2006 11:19 AM
eBay 3-burner stove Frederick L. Simson Classified Archives 0 02-01-2006 09:43 PM
Bucket for One-Burner Stove Legacy Posts Camp Cooking, Food & Recipes 2 10-11-2002 12:56 AM
