09-07-2019, 05:57 PM
Trailer: '85 u haul camper
VA
u haul 85 camper
Hi, anyone know where to get wheels for 1985 u haul camper. know that they are 13 inch tires, but is the 4.75 lug circle correct? any info, would be appreciated. Hadn't been able to find so far if I have correct lug size. thanks
09-07-2019, 07:00 PM
Go to uhaultruckparts.com, then to their eBay store. Part # for the wheel is 23516006. It is close to $100. Slightly different than the originals, does not have the little nubs for the small hubcap. The 4'5" measurement in the wheel description is the width, not the bolt pattern which is 5 on 4 3/4 circle. The offset is what makes the Uhaul wheels unique.
09-07-2019, 07:21 PM
VA
85 u haul
Thanks for the reply, will try this sight. thanks again.
09-08-2019, 08:25 PM
Trailer: Formerly U-Haul
U-Haul Camper
Bonnie White, I am not sure if you are aware but there is a "U-Haul Camper" group on Facebook. You are most welcome to come join us and enjoy sharing the experience of ownership with other U-Haul owners. Hopefully we will see you there.
09-09-2019, 05:10 PM
VA
85 uhaul camper
Hi, Would you know what holds the front window awning up, you can flip it up but something there is missing to keep it up all the time. Have a stick to prop it up right now. any info helpful !! thanks
09-09-2019, 07:52 PM
Trailer: U-Haul VT
They are called gas shocks. If you go to the UHAUL Facebook site you will find a spreadsheet in the files section that has a cross reference for many parts including wheels gas shocks window repair parts and many more.
09-10-2019, 03:55 AM
VA
uhaul camper
Thank you for the info., I will look at that section.
09-14-2019, 11:24 AM
Just take the hub off and clean it since you already likely need to pack the bearings. Take it to WalMart, Rural King, Tractor Supply, Northern Tool, etc and find a reasonably prices off the shelf wheel that fits your hub. Make sure your tires are good to go for your Loaded Camper.
09-14-2019, 02:18 PM
Uhaul trailers use a sealed bearing hub that is not serviceable. They also use a different bolt circle for the wheels, 5 on 4 3/4 where the commonly used trailer wheels are 5 on 4 1/2. The Uhaul wheels also have an odd offset. Wheels are available on Uhaul's eBay store.
09-14-2019, 05:11 PM
VA
uhaul 85
Thanks again for the response. We finally figured out about the bolt circle. We just sandblasted the wheel and bought new tires. We now just need a spare. this camper has been a challenge to work on can't nothing locally but we are getting there.
09-14-2019, 08:03 PM
If you don't want to spend the $100 for a new wheel from Uhaul, look in the files on the Facebook group to see what years of Chevy Camaro's have the same bolt pattern, around the year 2000 maybe, and get a donut spare from one of them. Many parts are either no longer in production or unique only to the Uhauls. We sold our Uhaul and most of my spare parts.
09-15-2019, 09:04 AM
Trailer: 17' Bigfoot
If there is a problem getting wheel parts for the rig, why not just replace the axle with something that is standard? I did this with my Big Foot and I now have a completely standard axle, wheels, wheel bearings, brakes and etc. I also took the time to modify the height so I could have enough clearance to permanently install front and rear stabilizers.
09-15-2019, 11:52 AM
It's not a problem getting Uhaul wheels or new bearing hubs, it just is not cheap. Replacing the axle is the best way to get brakes as the 13 foot model does not have them, but in my experience most owners are not willing to spend the money. Same with the leaking windows, there are solutions, but again considerable work and money.
09-16-2019, 07:49 AM
I can appreciate the money thing for sure... I am not too afraid of spending the money on a unit that is 30 years old because it is lasting. I see these new rigs for $40 grand that only last a few years, and I don't mind spending $1500 for stuff that leaves me with a great rig that keeps getting better. This unit is one of my hobbies and I enjoy putting in better stuff. Being retired helps too.
