U-Haul Camper - replacement pipe for dinette? - Fiberglass RV
Old 07-29-2010, 08:46 PM   #1
L Brown's Avatar
Trailer: 1985 Uhaul 13' aka "Dandelion"
Los Angeles, CA
Hi all ~ just got a new-to-me '84 13' U-Haul camper. Unfortunately, the original pipe the holds the dinette table was lost and I'm trying to figure out something to use that's a suitable replacement. I stopped by Home Depot hoping to find a a similar 2" cylinder. They were not too helpful Any ideas on other places/resources to try? And is there a standard table "height" I should request if it needs to be cut down? Thanks for any insight/ideas you might have. ~ Lisa
L Brown is offline   Reply With Quote
Old 07-29-2010, 09:56 PM   #2
Trailer: Fiber Stream
You'd have better luck at an RV Supply store...
RV Furniture pedestal table legs, bases
Buy it online, or Camping World is another possibility. Here in San Diego there are several RV supply retailers to choose from.
Old 07-29-2010, 10:19 PM   #3
L Brown's Avatar
Los Angeles, CA
Perfection! Thanks so much!
Old 07-29-2010, 10:35 PM   #4
Trailer: U-Haul
Lisa, On my U Haul the original post for the table was modified to fit another custom table top. The previous owner had to add a thin adapter tube to the top end of the pipe/post in order to fit the new fitting on the table. As such the original table could not be used because with the adapter the tube was too large in diameter. As I wanted to use the original table I removed the adapter and the tube once again fits the original table.
So I would suggest you check the diameters carefully as the U Haul stuff seems always to be "special" in one way or another and I suspect a standard table post will be too big in diameter.
Hope this helps,
David A. L.
David A. L. is offline   Reply With Quote
Old 07-30-2010, 12:34 PM   #5
Bridget T's Avatar
Trailer: 1985 U-Haul CT13 ft ('The Mothball')
Actually the table post is standard and super easy to find, it is 29 1/2 inches tall. I found a replacement easily at my local RV store for 10$, I notice that camping world also has some:
Table Leg - Product - Camping World
Bridget
Bridget T is offline   Reply With Quote
Old 07-30-2010, 05:43 PM   #6
Matt in SV's Avatar
How do the CT table legs anchor? I have a VT and it has a sort of complex folding leg mechanism slash mousetrap.
Planning our next Escape!
Old 07-30-2010, 07:16 PM   #7
Scott B.'s Avatar
Trailer: 13 ft Burro
Most use one of these mounts either surfaced mount or recessed mount.
Scott B. is offline   Reply With Quote
Old 07-30-2010, 07:36 PM   #8
Trailer: U-Haul
Be aware that at least one style of table supports made by TIIDEE in Dayton, Ohio use a different diameter pipe.
Bests,
David A. L.
Old 07-30-2010, 08:33 PM   #9
Bridget T's Avatar
In my CT there was the recessed mount which I'm pretty sure is original (quite rusted) as shown on the left of Scott B's post. I had a post but it was very rusted and wiggly, getting a new posthelped a lot. The fiberglass table has a surfaced mount fiberglassed into the bottom.
I will add that the CT's original table is really hard to get around. You basically have to lean the table over to get in - even if you are a thin person. We are right now trialling a prototype of a new table which is half the size, but two pieces which hinge together. We are pretty pleased with this arrangement - less table space but way easier to get in and out when it is set up as a dinette. And then we just unfold it to use for the bed support.
Bridget
Old 07-31-2010, 03:19 PM   #10
Pam Garlow's Avatar
Trailer: U-Haul 1985
I relocated the mounting flange for the table further back which shifts the table back and allows more room to get in. The table now 'overhangs' the back portion of the 'U' shape sitting bench. I don't really care because I do not seat 4 at the table (usually 2 max). I love the table pushed back. It makes the floor space much bigger feeling too!
Old 07-31-2010, 06:30 PM   #11
Cool
Looking Good!
Old 07-31-2010, 10:27 PM   #12
Bridget T's Avatar
Pam,
I like the way you moved the table back, was it difficult to make a new recessed spot for the moved flange?
Bridget
Old 08-01-2010, 09:17 AM   #13
Pam Garlow's Avatar
Mine is not using the recessed holder. Its still in the floor, I believe, under the carpet. Previous owner had installed a surface mount pipe holder which I simply removed and screwed back down where I wanted it. (simple simple !) If you ck the photo, you can see the type of mount. It's a low profile one, and they got it from a marine supply company.
Old 08-04-2010, 03:24 PM   #14
L Brown's Avatar
Los Angeles, CA
Thanks for all the great advice. I've done careful measurements of the existing anchors on the tabletop and floor (looks like original equipment; floor anchor is the recessed style) and will try to find a store in the LA area that carries this so I can go in and compare -- it looks like about 2 1/8". Or else, I'll try mail order and take my chances. Luckily the part is not too pricey
dinette, table, u-haul
Toy U-haul camper wanted Gary Z General Chat 3 04-03-2009 07:24 AM
U-Haul Camper Forum... R.I.P.??? Buck62 General Chat 6 02-09-2007 03:30 PM
I Need a Stock Rim for a U-Haul 13' Camper Buck62 Towing, Hitching, Axles and Running Gear 20 12-15-2006 05:23 PM
U-Haul cooktop replacement Jeanne and Steve Problem Solving | Owners Helping Owners 15 05-23-2006 04:16 PM
toy u-haul camper on ebay Curtis Hamilton General Chat 0 01-01-1970 12:00 AM
