U-Haul Camper Trailer Windows - Page 3 - Fiberglass RV
Old 12-31-2017, 08:18 AM   #29
I don't know of anyone finding a replacement door window, other than using a solid piece of glass which would make it a non-opening window.
Old 12-31-2017, 09:44 AM   #30
moonpies4misfits's Avatar
Trailer: Uhaul
Was thinking of that as an option. I replaced our door window on our Scotty Sero with a piece of Lexan and a new frame but the frame fit the existing opening. This will be more challenging.
moonpies4misfits is offline   Reply With Quote
Old 12-31-2017, 09:56 AM   #31
Just get a piece of glass, or lexan to fit directly into the rubber weatherstrip. Automotive safety glass would work. I don't know the thickness of the fiberglass at the door window opening, but assuming it is 3/16" thick as at the side windows, and if you use 1/4" thick glass, then the AS1456 weatherstrip would work good as one groove is 3/16 and the other is 1/4". Or you could get a custom window made to fit. Look on eBay for RV windows or teardrop trailer windows, as there are always cheap windows there. You might get lucky and find one that will fit.
Old 01-01-2018, 02:18 PM   #32
Trailer: 1984 13' UHaul
Louisiana
I went the easy way. Piece of smoked lexan. Cut it to fit and screwed it in with black windshield sticky rubber-like sealant. Used decorative caps over the bolts. No leaks. Looks great.
itlives is offline   Reply With Quote
Old 01-01-2018, 04:16 PM   #33
Trailer: Uhaul
I like the look and seems pretty straightforward! I like the idea of leaving the existing opening if I want to put back a framed window in the future. What does it look like from inside? I don't see the decorative caps on outside. What did you use to cut the curved corners? I have a decent Jigsaw but guessing I would need a finetooth blade. Is it black weather stripping you used?
Old 01-01-2018, 04:19 PM   #34
Trailer: Uhaul
How did you go about replacing the door hinges? They look great.
If the door window is out, is there access to the inside of the door?
Mine doesn't seal 100% and old door/hinge screws are wobbly.
Old 01-01-2018, 07:43 PM   #35
Louisiana
On the inside is just the bolts and unlock nuts. They are covered by the curtains. The decorative caps are black. You can get them at Lowe's. A fine tooth blade is all you need.
I made a template out of cardboard and cut the Lexan a little larger.
A simple fix for me.
Old 01-01-2018, 07:56 PM   #36
Trailer: Uhaul
Sounds like a good mod. Thanks for the suggestion!
u-haul, windows
To pull out my windows or not pull out my windows??? Alyson Brown Care and Feeding of Molded Fiberglass Trailers 15 04-30-2017 07:24 AM
Windows, windows, windows Matt4483 Problem Solving | Owners Helping Owners 24 02-10-2016 01:50 PM
For Sale: Scamp windows, vintage Hehr windows, miscellaneous stuff Steve_N_Janna Parts: Buy | Sell | Trade 5 10-02-2013 09:02 PM
Changing side windows on boler to radius windows. screamin_flamesfan Modifications, Alterations and Updates 3 09-11-2013 07:59 PM
Replacing the rectangle aluminum windows with modern rounded corner windows Evergreen Modifications, Alterations and Updates 16 10-29-2010 12:09 PM
