U-Haul CT 13 bounce - Page 2 - Fiberglass RV
Old 05-30-2013, 01:38 PM   #21
MsRubyLu-Kathy's Avatar
Trailer: 1987 Bigfoot 13'
My hitch tightener cam today and I'm going to be using it tomorrow. I did play with the hitch last week and there isn't much side to side movement but there is a lot of vertical play in mine so I think this is going to work great. I will report after I get back from my mini trip.
MsRubyLu-Kathy is offline   Reply With Quote
Old 05-30-2013, 01:46 PM   #22
As cheap as I am, I'm thinking of ordering that tightener that Greg recommended. When you install it, be sure that it is in such a way that it is pulling the ball mount DOWN.
Old 05-30-2013, 04:06 PM   #23
Bob, in case you're interested here is the instruction sheet that came with it. I'll use it tomorrow and be back Sunday and report on how it worked
Old 05-30-2013, 04:13 PM   #24
Thanks Kathy, it's really a simple device, and almost exactly like the one I made other than mine has a longer bottom plate.
Old 06-02-2013, 06:21 PM   #25
I'm back from my first trip. I did use the Hitch Tightener and it worked well. I checked the tension on the lock nuts before I left the campground this morning and they were still nice and tight when I got home. It was much quieter. You can still feel a little bounce from the trailer but it doesn't jerk near as much and it also doesn't sound like you are destroying things back there.
u-haul
Equalizer Hitch to Reduce Bounce? Scott S. Towing, Hitching, Axles and Running Gear 11 11-19-2009 09:16 AM
"Bounce" Alf S. Care and Feeding of Molded Fiberglass Trailers 16 10-08-2008 08:09 PM
bounce... could it be bad tug shocks? Scott S. Care and Feeding of Molded Fiberglass Trailers 15 10-07-2008 05:46 PM
Trailer Bounce Taylor Problem Solving | Owners Helping Owners 5 07-19-2007 09:39 AM
bounce... could it be bad tug shocks? Scott S. Towing, Hitching, Axles and Running Gear 0 01-01-1970 12:00 AM
