U-Haul CT-13 Drip cap - Fiberglass RV
Old 02-12-2012, 03:07 PM   #1
Mouse's Avatar
Trailer: U Haul CT13
How are other people solving the rain dripping through the door weather seal problem?
Here I have a temporary plastic sheet acting as a drip cap. It works and it is easy. Are there more elegant ways?
Mouse is offline   Reply With Quote
Old 02-12-2012, 05:36 PM   #2
mmeyer's Avatar
Trailer: U-Haul VT
Indiana
sounds like you need a new door gasket. they get old and don't seal too well up top.I used this on my VT
Trim Seal- Vinyl Quick edge with round rubber bulb on the side
25' is enough for two doors so if you have some left over you can sell or give it to someone in need. Kevin A got my leftovers.
Mike
mmeyer is offline   Reply With Quote
Old 02-12-2012, 06:40 PM   #3
We have window leakage problems, and until we overhaul them we are using a canopy over the trailer. Camping World sells a flexible RV gutter that sticks on. I have put it above all the windows and it helps with water that runs off the top of the trailer. Our door doesn't leak. Bob
Old 02-13-2012, 06:41 AM   #4
Bruce Thomas's Avatar
Trailer: Hunter compact jr
Indiana
I think I know what he's talking about...ours doesnt leak either but when you open the door it's setting there waiting to fall on you above the seal, kinda gathers there at times. lands riht at your feet as you open ...I think a stick on type gutter seal or something across the top would fix it.
I have the brackets made to put our awning on this year and its above the door so maybe that'll stop most of it........I think
Bruce Thomas is offline   Reply With Quote
Old 02-13-2012, 07:38 AM   #5
mmeyer's Avatar
Trailer: U-Haul VT
Indiana
I put an extra piece of self stick foam about 1 " wide above the door gasket seems to alleviate most of it, any way here is the link to rubber track for rebuilding the windows he will need that.Weatherstrip-Trims, All Rubber Glass Run Channels with Flocked Lining
unless the other gasket which holds the window in the door is toast you should be able to reuse it. it is a different style than the one that holds in the emergency window on the VT as it does not use a locking spline, the edges lock into each other. Don't know about CTs as I have never seen one in person.
Mike
Old 02-13-2012, 09:37 AM   #6
Mouse's Avatar
Great ideas all!
My current solution is working really well for my door. No wet surprises!
I've replaced the weather stripping and it works for air and creatures but some water always made its way in until now.
Above the windows, I will try the EZE gutter and/or J cap from the hardware store.
Snap cap/Button cap question Kevin K Problem Solving | Owners Helping Owners 5 06-19-2012 11:50 AM
Replacing Scamp aluminum drip edge Evergreen Modifications, Alterations and Updates 8 02-17-2011 08:57 PM
Drip Caps Eddie Longest Care and Feeding of Molded Fiberglass Trailers 2 09-22-2009 06:11 PM
Looking for a 29" Drip Cap Sharyl Allender Problem Solving | Owners Helping Owners 6 08-04-2009 11:33 PM
Drip caps over windows Legacy Posts Problem Solving | Owners Helping Owners 1 06-02-2003 09:36 PM
