U-Haul CT13, need parts and help - Fiberglass RV
Old 07-16-2016, 06:50 AM   #1
Trailer: U-Haul
New Hampshire
Hello all!
I am new to this site but have been reading posts for a while now. I just purchased a 1984 U-Haul 13. It is in need of work but is in good condition. I would like to bring this unit back to original. Currently, the bunk bed wood board and support posts are missing. I do have the main hinge and cushion. I am also missing one of the small corner cushions that is placed on the lower bunk. If anyone out there has these items, please let me know!
Additionally, there are endless posts regarding window parts, whether it be gaskets, seals, channel felt, etc. I'd like to restore my windows. Does anyone have a list of all part numbers of items required and where to purchase? I really need the window channel felt and the rubber seal that fits in the outer track that prevents dirt from entering the outer channel.
Lastly, my furnace is inoperative. I thought it was the thermostat. It was the original "Duo-Therm". I removed it and it was brittle from age so I am replacing it. There was no power to the thermostat so I ruled that out. I contacted the two wires together and nothing came to life. There is power to the furnace but that's as far as I can chase it while still tucked in to that tight area. Does anyone have a clue where to go from here? Is there a place that refurbishes furnaces that mine can be sent to?
That's all for now. Ant assistance would be appreciated
Thanks!
DenisB is offline   Reply With Quote
Old 07-16-2016, 07:07 AM   #2
Pam Garlow's Avatar
Trailer: U-Haul 1985
Hi, Denis, welcome to fgrv! You will find a huge base of knowledge here as well as many friendly fg egg owners. There are rallies galore to attend, too!
Many UH owers have 'dual citizenship' here on this site as well as the UHaul specific facebook site which has lists and parts specs and all sorts of other coolio things in one place. Check it out. https://www.facebook.com/groups/UHaulCamper/
Old 07-16-2016, 07:50 AM   #3
We will be at Sebago Lake Maine with our Uhaul tomorrow and Monday. You anywhere near there Denis
mary and bob is online now   Reply With Quote
Old 07-16-2016, 02:13 PM   #4
Trailer: U-Haul
New Hampshire
I will not be in that area. That is a hike from me!
Old 01-24-2017, 02:32 PM   #5
Trailer: U Haul
Looking to replace my "storage cabinet" (next to the fridge).....any ideas on where to find one ? (the original is a fiberglass Insert....but cracked on the corners). May have a cabinet maker try to "replicate" it if no luck finding one. To all out there....let me know. Much thanks......rickeelee
rickeelee is offline   Reply With Quote
Old 01-24-2017, 05:17 PM   #6
Trailer: UHaul CT13
Iowa
Denis,
I hope this link works... I believe it's a fairly involved description of someone on this site rebuilding their furnace.
repairing Uhaul furnace
[It's been quite a while since I looked it over.]
Gary
"You'd care less what people think of you if you knew how seldom they did." E Roosevelt
groys02 is offline   Reply With Quote
Old 01-24-2017, 05:28 PM   #7
We took ours out, resulting in much more storage space. No it's not for sale. Or repair yours with some fiberglass resin and cloth
Old 02-03-2017, 04:06 PM   #8
Trailer: uhaul
gaskets
i sent you a pm about felt and gasket material
wetasswilly is offline   Reply With Quote
Old 02-27-2017, 01:13 AM   #9
Trailer: U Haul
I'm looking to find a simple...user friendly " owner's guide/handbook " for the CT13. The one I downloaded from this site is quite technical...and more of a " repair " manual.
Is there anything that addresses the basic "systems " ( furnace, electrical, fridge and H2O) that is simple and "straight forward "......not about technical repairs by UHaul ?
Thanks! Rickeelee
Old 02-27-2017, 05:53 AM   #10
Rick; in the document center you can find the Users Guide, the Repair Manual, and the Parts Manual. The Users Guide probably does not have all the information you want as Uhaul used instructional decals all over the trailer, most of which are probably gone now.
Old 02-27-2017, 07:13 AM   #11
Trailer: Bigfoot B-17 CB
Thanks! Rickeelee
Check the document center or Google for the make and model of the individual appliance. Refrigerator and furnace instructions should be available. The appliances and electrical may have been changed by a previous owner.
Jack L is online now   Reply With Quote
Old 02-27-2017, 09:01 AM   #12
Furnace instructions may be on the inside of the cover. It is an electronic ignition furnace, no pilot light that has to be manually lit. Fan will run a bit before furnace ignition. Operates on 12 volts. Water system is a basic hand pump. Stove burners are manually lit with a match. Originally there was an ice box, and some had a roof top swamp cooler that had a pump and water tank in the right front storage compartment.
Old 02-27-2017, 09:38 AM   #13
Scoboatn's Avatar
Trailer: Burro
I used to have a U-Haul, but I am currently restoring a Burro. I can't remember if the window frames & construction are the same or not? If you look under the Baja Burrito Resto Mod posts under Burro, I have a detailed parts list for a window rebuild and pictures. Not sure if this will help or not. Good luck.
Scoboatn is offline   Reply With Quote
Old 02-27-2017, 12:57 PM   #14
Trailer: UHaul
Bunk Bed details
If you have the hinge, the bunk is a pretty straightforward project. It is just a piece of plywood with two hinged pieces on the ends that will allow you to fold it past the cabinet and conform to the curve when laid down. It's just held up by some folding table legs you can get on the Amazon.
I took mine out but have it still. A pattern for you could be arranged.
Michael
GabbyB is offline   Reply With Quote
u-haul
U haul ct13 help with tail lights Becky B Problem Solving | Owners Helping Owners 13 08-13-2012 07:59 PM
Need help locating U-haul parts Randy Bishop Problem Solving | Owners Helping Owners 4 05-22-2012 05:13 AM
Front window replacement on U haul CT13 daman4799 Modifications, Alterations and Updates 14 07-21-2011 04:57 AM
U-Haul CT13 Table Dimensions Gary P Problem Solving | Owners Helping Owners 4 10-10-2009 02:13 PM
Parts Parts Parts Ken Gronsdahl Classified Archives 5 07-06-2008 11:05 AM
