U-Haul CT13 Table Dimensions - Fiberglass RV
Old 10-10-2009, 08:55 AM   #1
Gary P's Avatar
Trailer: 1984 U-Haul
Does anyone know the dimensions of the rear table in a U-Haul CT13?
I have to make one from scratch.
I could measure the recessed area on the benches and get that but it looks like the table sticks out over the benches in pictures I am seeing.
Thanks...
Gary P is offline   Reply With Quote
Old 10-10-2009, 10:00 AM   #2
Raya's Avatar
Gary, I'll measure mine for you and then post back. I believe it fits completely within the benches, but why not find out for sure.
Raya
Edited to add: Okay, here we go:
First of all, the table is nearly a square, but is slightly rectangular. It fits down into the grooves on the edges of the benches, so that the top of the table is flush with the tops of the benches when it is lowered. It has a central pedestal type leg. It does not stick out past the front edge of the bench/closet/kitchen enclosure area.
The two corners that face into the trailer are cut off on a diagonal to facilitate getting into and out of the benches when it is in table mode. But of course you could make those rounded or however you wanted to.
The measurement across from bench to bench is 32-1/4"
The measurement from back to front is 28-7/8"
The flat part of each diagonal corner cut is 10-1/2"
The corners of the cut off diagonals are a bit rounded, but they start about 7-1/2" in from where each corner would be (i.e. before you cut them, measure in about that far along the edges and make your diagonal cut between them - face should be about 10-1/2" then when you are done.
Edit #2: I remember you were asking about possibly using Scamp cushions. I don't think it would be a good enough fit to make it worthwhile, because the Scamps are much more rounded at the ends (hence, so are the cushions). Where the U-haul is more square with rounded off corners, the Scamp is more "pooched out" in the middle.
Old 10-10-2009, 11:11 AM   #3
CindyL's Avatar
Illinois
Someone on the uhaulcamper forum mentioned that some of the UHaul cushions fit into their Casita Freedom Deluxe. That person did not try them all. Maybe Casita owners can measure their cushions here and see if this might be the route to go.
CindyL
1988 Bigfoot Silver Cloud, "The Egg Carton"
CindyL is offline   Reply With Quote
Old 10-10-2009, 01:48 PM   #4
Gary P's Avatar
Raya: Thanks for the very detailed dimensions, just what I was looking for.
CindyL: I didn't think it was going to be as easy as buying a set of factory Scamp cushions.
I'm just trying to get out of making mine. I dred that part of the restoration.
Old 10-10-2009, 02:13 PM   #5
Raya's Avatar
I won't say that sewing "proper" slipcovers is easy, but on the other hand, cutting out the foam is easy-peasy with an electric turkey carving knife. Just cut it a little bigger than the end size you want, and then it "plumps" the cushions nicely.
Remember, once you have the foam cut, you can always use something like sheets or fleece and safety pins to get you going with a quick slipcover
u-haul
CT13 for sale - Southern Oregon James T Classified Archives 5 10-22-2010 12:44 AM
Towing a UHaul CT13 Mitch Scott Towing, Hitching, Axles and Running Gear 5 04-15-2010 05:11 AM
WTB window handle for uhaul CT13 mszabo Classified Archives 4 09-18-2009 06:38 PM
1984 Uhaul CT13 FOR SALE mszabo Classified Archives 9 09-15-2009 08:33 AM
scamp table dimensions? andy vaughan Problem Solving | Owners Helping Owners 5 07-29-2008 11:16 PM
» Trailer Showcase
Parkliner
DJO
Iggy
emij
