U-Haul hook up box - Fiberglass RV
Old 01-13-2012, 07:16 AM   #1
Trailer: U-Haul CT13
U-Haul hook up box
I picked up my U-Haul CT 13 last weekend. I know nothing about campers. The box on the side for water and electric hookup has what looks like a place to attach a standard water hose and a yellow thing that looks like its made for pouring water into or sliding a hose into it.
What are they for? I haven't had a chance to open things up and trace the connections.
Jim
Sundance is offline   Reply With Quote
Old 01-13-2012, 07:23 AM   #2
Jim, I don't own a U-Haul, most of the connections are pretty standard however. I'm betting that YES that's a water connection to hook you up to "city" water. Check for leaks before turning on fully.
You may have need for the documents in the Document Center for the U-Haul: Fiberglass RV - Document Center - U-Haul
Old 01-13-2012, 09:51 AM   #3
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
Hookup on the left is for water hookup. There is a pressure regulator built in. On the right is a flip cap that allows you to pour water into the tank, which is under the rear seating area.
Welcome to the UHaul club.
Old 01-13-2012, 10:11 AM   #4
Thanks
Thanks for the information. Makes sense now.
Jim
Old 01-13-2012, 11:18 AM   #5
Trailer: U Hall VT
Smile
Jim
You might want to run bleach through your system to clean it out. Welcome home
Roger Kimble is offline   Reply With Quote
Old 01-13-2012, 12:30 PM   #6
CindyL's Avatar
Illinois
Welcome to the Uhaul family. We have the big sibling to your Uhaul.
CindyL
CindyL is offline   Reply With Quote
Old 01-15-2012, 07:20 PM   #7
Trailer: 28' Bigfoot Silver Cloud
Oak Park, IL
Our VT has the potable water filler next to the city water hookup just like you have mentioned. However, we have another potable water filler on the right rear of the trailer, too, just left of the tail light. I wonder if the original VT had two fresh water tanks? Of course, none are left now so I can't just look. When we bought the VT in 2007, the PO had put in a large water tank in the space between the two rear benchseats (or in the space under the bed). We took that out to gain the storage space back. I assume the tank sat under the passenger side rear bench seat, but I don't know for sure. Any VT owners know?
Old 01-15-2012, 10:06 PM   #8
Lizbeth's Avatar
You might want to make sure there is still a tank before you stick the hose in the filler and turn it on! Don't want you to end up with a swimming pool in your trailer.
Old 01-16-2012, 02:54 PM   #9
mmeyer's Avatar
Trailer: U-Haul VT
Indiana
My Vt did not come with a water tank, but when I replaced all the plumbing it was apparent that like Kevin's we had a city water loop and a loop that was fed by a tank. In my case it was simply a hose connection that terminated under the trailer to the left of the door. The faucet in the sink and shower could be fed by the pump which took it's suction from a hose attached to the hose connection dipped into a bucket or from city water through the pressure reducer connection either way. Original was to be fed from a tank that sat under the left rear bench next to the battery. A drain spigot was located under the left tail light to drain this tank.
Michael J
mmeyer is online now   Reply With Quote
Old 01-16-2012, 03:22 PM   #10
Thomas G.'s Avatar
Jim
You might be interested in the UHaul user's manual that I have posted here in the document center under UHaul:
Fiberglass RV - Document Center - UHaul Camper User's Guide
u-haul
Want to replace the Ice Box in my U-haul with fridge Christina Modifications, Alterations and Updates 19 10-20-2014 06:32 AM
Need to Hook Up? Roy in TO Problem Solving | Owners Helping Owners 5 03-06-2010 07:58 PM
Cable hook up Lenna F Problem Solving | Owners Helping Owners 11 05-26-2008 03:51 PM
Hook-up Alignment andre robillard Problem Solving | Owners Helping Owners 1 04-26-2007 07:21 AM
