Uhaul 13' windows -- repair or replace? - Page 2 - Fiberglass RV
Old 04-13-2009, 10:40 PM   #15
Trailer: 1977 Boler
Search for eBay seller "callencampers" as they have lots of windows plus in my case they custom made them.
RogerH is offline   Reply With Quote
Old 04-23-2009, 01:00 PM   #16
Trailer: U-Haul CT13
Here you go, two sites to contact them
http://www.callencamper.com/
http://shop.ebay.com/merchant/callencamper...QQ_fromZQQ_mdoZ
GRMeyers is offline   Reply With Quote
Old 04-23-2009, 07:05 PM   #17
Trailer: 1984 U-Haul 13 ft
Upstate New York (near Albany)
Smile
My Uhaul is currently at an rv place to have my windows resealed & installed again (hopfully they'll do it right with butyl tape & not that nasty silicone). They are supposed to install new gaskets. If they are done correctly when I pick it up, I will post on this site & Uhaulcamper site the source of the gasket materials. Please wish me luck, as I'm so tired of these leaky windows. They're a pain to install unless you have a lot of patience (been there -tried one-thought it was laced correctly, then the gasket shrunk).
Patty S. is offline   Reply With Quote
Old 04-23-2009, 07:19 PM   #18
Carolyn Patterson's Avatar
Trailer: 16 ft U-Haul VT / 2004 GMC Safari
Patty,
If it's any help, the former owner of my trailer said they removed all the windows and resealed them - yet, my Emergency window 'seeps' during a hard rain storm....Ok, Ok, I admit, I've tried to caulk it, but it still "seeps" sometimes, but not all the time...not enough to make me rip it out..
That one is the only one that leaks 'just a bit'...
Good luck with your re-do...
Will you be attending the rally on Lake Erie this September? I'd love to go to another fiberglass rally and have some "Uhaul" company..
Carolyn Patterson is offline   Reply With Quote
Old 04-23-2009, 07:24 PM   #19
Ami P's Avatar
Trailer: U-Haul VT16 1985
The all-rubber window seals (channels) that fit the UHauls are part # AS1268, available here:
http://www.perfectfit.com/15594/156059/Gla...ked-Lining.html
Ami
Ami P is offline   Reply With Quote
Old 04-23-2009, 07:41 PM   #20
Patty,
Hi Carolyn,
It sounds like it would be fun, but I don't think I can get the time off. If I can have the time off from work, Ill PM you.
Old 04-23-2009, 07:45 PM   #21
Julia O.'s Avatar
Ami
Ami, Sorry to hear about your blowout, and glad that it wasn't worse. I appreciate the part info, but if you had time to comment on what it was like to actually do the window repair, I would really appreciate it. I just dropped my trailer onto a seasonal site where I'll finish most of the work it needs. Windows are job #1, and I'm still researching the right solution. Can you elaborate on the tools & techniques that worked for you?
Thanks in advance,
Julia
Julia O. is offline   Reply With Quote
Old 04-23-2009, 08:28 PM   #22
Ami P's Avatar
Julia,
Kevin61, a member on this site has a video re window repair, including the tools needed. The job takes a little skill. If you decide against doing it yourself, I suggest getting the parts and calling a mobile auto window guy.
Ami
Old 04-24-2009, 10:39 AM   #23
Post
Ami
Thanks, Ami
Old 04-24-2009, 04:38 PM   #24
Raya's Avatar
Ami,
Is that part the channel that the window panes "ride" in, or the seal that goes between the whole window and the body of the trailer. I'm thinking you said it was the seal, but it looks more like the sort of brushy stuff that the windows would ride in
Thanks ahead for clarifying,
Raya
Old 04-24-2009, 07:22 PM   #25
Ami P's Avatar
Raya,
It is the same thing. The original Uhaul channel had a metal core which eventually rusted, producing ugly stain-runs on the gelcoat when rain water drained from the natural weep holes. The AS1268 all-rubber channel is better, more flexible, no rust and it's reasonably priced. - Ami
Old 04-24-2009, 08:23 PM   #26
Raya's Avatar
Oh, so the same piece is used for the channel and the seal around the windows (that holds them into the trailer)? Huh, I never would have guessed that. I still don't see how that can "grip" both the glass and the fiberglass walls of the trailer though - I was expecting to see more of an "H" shape.
But I do see a U-haul in your avatar , and it sounds like you've used it.
Thanks
Raya
Old 04-24-2009, 09:38 PM   #27
Ami P's Avatar
I don't think it is what you call "the seal" that seals the window frame to the fiberglass cutout. I have never removed the window frame. The "channel" seal is part AS1268 and the glass moves laterally or vertically in it and it is placed between the edges of the glass and the window frame. The material that seals the frame to the cutout is putty, epoxy sealer, silicone, etc.
Ami
Old 04-25-2009, 03:27 PM   #28
Jeanne and Steve's Avatar
Trailer: Casita 16 ft 1984 and U-Haul CT13 1985
... I have never removed the window frame. The "channel" seal is part AS1268 and the glass moves laterally or vertically in it and it is placed between the edges of the glass and the window frame.
Hi Ami,
I love the thought of replacing the channel seal without removing the windows / window frame! Did you just press the channel seal into place or did you first add a little sealant/adhesive to the bottom of the channel seal or window frame?
Jeanne
Jeanne and Steve is offline   Reply With Quote
u-haul, uhaul, windows
Uhaul Side Windows RICK H. Problem Solving | Owners Helping Owners 80 12-12-2016 05:07 PM
Replace weatherstripping Jane K Problem Solving | Owners Helping Owners 5 09-10-2015 12:48 PM
Need to replace windows 1971 Compact jr Tania Problem Solving | Owners Helping Owners 1 06-15-2010 05:41 PM
refrigerator - repair or replace? Rye Livingston Problem Solving | Owners Helping Owners 5 08-02-2007 09:21 PM
Do I Replace converter or Not? Chris and Ame Care and Feeding of Molded Fiberglass Trailers 14 07-27-2007 08:13 PM
