Uhaul converter - Fiberglass RV
Old 10-31-2012, 10:15 PM   #1
uhaulin's Avatar
Trailer: Uhaul ct-13
Uhaul converter
Anyone recommend a new converter for me? Electrical is very foreign to me. I have been doing as much reading as I can but I feel I can't find the simple answer I am looking for. So what have you guys changed to? I am looking for an easy swap out. Thanks you are all so helpful
uhaulin is offline   Reply With Quote
Old 11-01-2012, 05:18 AM   #2
I used a Progressive Dynamics 4045, but it wasn't an easy swap out. It mounts to a vertical surface and needs some ventilation. I have also added some 110 outlets and lights, plus some 12 volt lights, so I've done a lot of new wiring. I also rewired the tail lights. Check your tail light wiring cords , mainly where they exit the tongue underneath, ours were cracked down to bare wire.
Old 11-01-2012, 05:29 AM   #3
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
I stuck with the original converter, but like Bob says, many converters with the integral fuse panel are designed to fit into a vertical wall.
What some have done is to install a converter with a fuse panel right next to it. That way, you can just move the wires over from the old converter to the new converter. It would take a little wiring from the converter to the fuse panel, but it is simple.
Sample components.
Converter with smart charger
Fuse Panel
Another Fuse Panel
Old 11-01-2012, 02:30 PM   #4
uhaulin's Avatar
Thanks for the input
Old 11-01-2012, 06:12 PM   #5
Trailer: U Hall VT
Smile
I just fixed my old one, which is different than the 13's
Roger Kimble is offline   Reply With Quote
UHaul Converter - Peering Inside Thomas G. Care and Feeding of Molded Fiberglass Trailers 30 01-15-2013 12:47 PM
Origianal UHaul Converter doug in oregon Electrical | Charging, Systems, Solar and Generators 8 09-27-2012 01:57 PM
Converter ted saxton Problem Solving | Owners Helping Owners 10 09-17-2011 07:19 PM
Converter Darnelle Care and Feeding of Molded Fiberglass Trailers 5 04-28-2010 07:24 AM
need a converter? Jeanne and Steve General Chat 2 12-13-2007 02:53 PM
