This may be a totally stupid newb question but......My CT-13 has the original facet, it is either a manual pump or when pulled back runs a
battery operated water pump. I hooked up the water from the feed at the campground and went in to test the facet, to my surprise neither the hand pump or 12 volt water pump made any water appear in the sink
Upon further inspection, i did not even see a flow of water filling the water line, I am fairly sure there are no blockages, the water line under the sink is clear re-inforced poly line and the system has a pressure regulator built into the camper and one threaded onto the end of the water line as well, I removed the secondary pressure regulator and still had no luck, what am I doing wrong? PS I did not fill and test the internal tank because I really didn't have the need on this trip, but I would like to know why the hard line from the campground did not work
Please don't tell me it was as simple as pushing the facet handle the other way
