Uhaul Door hinges - Fiberglass RV
Old 09-24-2009, 10:36 AM   #1
Trailer: U-Haul CT13 ('Pearl')
SW Ohio
Unhappy
Pearl is slowly being worked on. Fixed the gas line, working on the soft spot in the floor...doing the dinette mod. Just found out the old solar still works and had 17.8 volts...zap. I am just walking around the edges of the electric now!
I need to replace the wooden blocks that the door hinges bolt into on the trailer. Do I need to use oak or some other hard wood or will clear pine do OK?
Thanks for the input!
Pat B Ohio is offline   Reply With Quote
Old 09-24-2009, 11:01 AM   #2
Raya's Avatar
Hi Pat,
When you say "bolt into" do you mean that bolts go through it and then you have nuts, so it's acting as a backing plate? Or is something threading into it, like a screw?
If the former, I would use pre-made fiberglass board, myself. (www.mcmaster.com, the plain green board is fine) Or I were going to use wood, I would not use a soft wood like pine.
If the latter, I would be tempted to change it to a through-bolted style, since it's door hinges, or to tap a piece of the fiberglass board (for tapping I'd use the red stuff), and then use a machine screw.
Mind you I'm saying this not knowing exactly how your hinges work. Can you describe it more?
Raya
Old 09-28-2009, 09:29 AM   #3
SW Ohio
The Uhaul hinges are held onto the body by three bolts. These bolts go through a piece of backer wood and are accessed via holes through the inner liner. I think they were glassed on but they have dry rotted. I am considering stabilizing a piece of ply with that penetrating epoxy and then using that. I have to slide it in place between the body panels, then glue it in place. Remember, I live in "Mayberry" so I have trouble getting stuff.....plus my budget is very sad.
Old 09-28-2009, 12:36 PM   #4
Trailer: Fiber Stream
Unhappy
I would recommend using the hardest wood that you can afford. I'm afraid that clear pine might be only a temporary fix, and you'd have to do it over again in a year or two...
Old 09-28-2009, 02:24 PM   #5
Raya's Avatar
Seems like anyplace you could slide a thin piece of wood, you could slide a thin piece of FRP board. If you have a *really* thin slot, I'd be thinking of a stainless steel or aluminum backer plate (SS being less problematic with steel fasteners). Alternatively, could you slip a very large fender washer in there?
McMaster-Carr will sell very small amounts of product, you can order online or via phone, and they have a fantastic web catalog. I typically have always received stuff the next day (with just regular shipping). It's a great resource. The green (cheapest) FRP board would do fine since you are not going to be tapping it. (I don't know how thin your slot is though).
Here is a link to that product [TinyURL made by me, leading to McMaster-Carr page. Alternatively, go to their main page, search "fiberglass sheets" then click on "plain fiberglass"]:
http://tinyurl.com/ydv4456
1/4" x 12" x 12" is about 16 bucks, and you'd have leftover material.
One caveat is that I can't see your exact situation, so take my recommendation with that in mind.
Raya
u-haul, uhaul
Door Hinges Phillip Modifications, Alterations and Updates 8 06-23-2009 02:34 PM
Door Hinges Wayne Boone Problem Solving | Owners Helping Owners 5 04-18-2008 09:05 PM
Looking for some Door Hinges.... mcnick Problem Solving | Owners Helping Owners 23 06-18-2007 06:52 PM
Trillium Door Hinges Legacy Posts Problem Solving | Owners Helping Owners 1 06-09-2003 05:51 PM
Looking for some Door Hinges.... mcnick General Chat 0 12-31-1969 07:00 PM
