I hope this isn't a duplicate post- I looked but didn't find one-
My
Uhaul CT13 has a leak and I cant find the source. The top of the closet is wet- I reach my fingers inbetween the ceiling double hull inside the closet and the it's wet- I guessed it was from the Fantatic Fan but I've pulled the carpet back exposing the ceiling and it's pretty dry around the fan and pretty dry under the
solar panel. Also, I'm a bit confused about the double hull- can someone explain how the double hull is put together in the Uhaul-I see internal hull seems to end on either side of the fan leaving the outter hull (under the carpet liner)as the main ceiling. Am I looking at this right? Also can someone explain why I dont see the seam of the outter hull that should run down the inside of the hull (under the carpet liner) Is it fiberglassed over on the inside?
My leak is also running down the sides inbetween the hulls to the lowest point of the trailer (under the front sofa) -do the running
lights ever need new gaskets?- I'm befuddled
