03-21-2012, 06:13 PM
Trailer: Casita, previously u-haul ct13
Virginia
Uhaul signal lenses, how to remove.
Does anyone know how to remove the lenses for the signal lights on the Uhaul CT13? Especially the upper ones. I would like to clean them and replace bulbs and reseal them. The screws are rusted and finding it difficult to remove. I don't want to break the lenses trying to take off so just thought I'd ask you wise ones. Thanks
03-21-2012, 06:57 PM
Diane, do you mean the rear tail lights?
I took mine off today and after the 4 screws were out, they just came off. If someone glued yours in, it may take some finesse.
03-21-2012, 07:09 PM
Virginia
I tried my best to remove the upper ones today and the screws were rusted. So I may have to cut them off with the handy dandy Dremel tool.
Thanks Again Thomas!
03-21-2012, 07:17 PM
Not sure we are the same page. The lens is one piece with amber on top, red on bottom, glued together. If the plastic insert in the fiberglass is spinning when you turn the screw, you want have to have someone hold it inside with pliers. Or won't the screw turn at all?
03-21-2012, 07:30 PM
Trailer: U-Haul 1985
Diane, the lights on the top corners of the trailer are the running lights. Are they the ones you're talking about? Since you can't get to the back of the running lights, you may have to try drilling the heads off the screws, then pull the lights off and then remove the screw shafts and the plastic anchors. For the taillights, you'd do what Tom G has just described.
03-21-2012, 07:58 PM
Virginia
Right Pam, I am talking about the running lights. Sorry If I wasn't clear enough. I have a dremel tool and a bunch of cutting blades. HA, I have never used this tool this much ever before the CT. It has really come in handy for cutting the rusted bolts off!
03-21-2012, 08:06 PM
Virginia
Thomas the screws do not turn at all. Seems someone before me has stripped the inside head of the screws as well. I will be getting to the lights you are speaking of last as right now am trying to clean the "Running lights", replace bulb and seal in case they might be a leaking point. Water...I got it! Kinda like a boat in the water, only in reverse, water in a boat.
03-21-2012, 08:10 PM
Virginia
Seems like you should just be able to pop the plastic lenses off the running lights without removing the whole fixture...any thoughts?
03-21-2012, 08:38 PM
If you want to take off the lenses, you don't have to remove the whole light assembly. But if you need to take the screws out in order to remove the lenses, then you might have to use a drill bit and 'drill' the heads off the screws.
03-22-2012, 05:51 AM
There is a notch on the end of the lens by the screw to get a flat screwdriver in to pop off the lens. I have a air powered die grinder with a thin cut off wheel that I sometimes use to grind a slot in a damaged screw head to get it out, other times cut the head off. The marker lights have a ground wire under one screw, under the light, clean it up with some fine sandpaper. The screw goes into those plastic inserts, which can be bought locally. Some of the inserts on my lights turned, so I just sealed around the light. The light base has half round notches for the wire to come out if so desired, so that is the possible leakage point. Replacement marker lights are available from Uhaul for a few dollars each but they don't say Uhaul on them in case you are doing a 100 point restoration, [I know you're not]. I bought a couple when I placed an order as shipping is free when you buy over $25. I have impact driver tools for removing tough screws, but wouldn't dare use it on a fiberglass trailer. Bob
03-22-2012, 06:04 AM
I just looked up the lights, $2.10, or just the lens for $.75
03-22-2012, 06:28 AM
Bob nailed it. I coincidentally had my clearance lights off yesterday, so I'm up on them.
There is a notch both on the side and the end of the colored lens. I used the widest screwdriver blades that would fit in the slots and simultaneously twisted both the side and end points to minimize the stress on these old sun baked lenses. As Bob said, the new ones don't have a UHaul logo.
A few pointers on getting out frozen screws.
Make sure your screw driver bit is not damaged, especially for power screwdrivers which tend to spin and round off. They are cheap to replace.
Try tightening a screw just a little, then reverse it, then re-tighten until it loosens.
Use penetrating oil and let it soak in for a few hours.
Pick up a little tube of valve grinding compound at an auto parts store. Apply a small amount between the screwdriver bit and the screw head. It really makes the bit bite in.
Left handed drills can be really handy. As you drill in the top of a screw the action of the drill is actually trying to unscrew it. Often the combination of the heat, vibration and torque will start the screw backing out. 13 Piece Left-Hand Drill Bit Set
03-22-2012, 06:32 AM
I forgot to add, if none of your clearance lights are working, the first place I'd look is at the ground wire which attaches to the frame where the wires come through the floor. Mine was all rusty. I am running a separate ground wire from the trailer light connector back to the inside wiring, as using the frame as a ground is inherently problematic.
03-22-2012, 06:38 AM
Tom: good info on the ground wire, I have one attached to the base of the propane tank mount, I wasn't aware of the one near where the wiring goes through the floor. I assume you mean at the rear of the trailer? I'll check it out. Bob
03-22-2012, 07:11 AM
Originally Posted by mary and bob
..... I assume you mean at the rear of the trailer?......... Bob
No, the wire goes up through the floor about midway. I also soldered all these plug in wires at that location as they were corroded and also soldered the ground wire to the frame. I'll attach my separate, backup ground wire back near the tail lights.
03-22-2012, 07:34 AM
Virginia
Oh Bob and Thomas, Thank you so much! We are on the same page now and all my question answered and more! I appreciate your kindness and willingness to help others.
03-22-2012, 02:18 PM
Tom: Good thing you mentioned that wiring, I hadn't looked close at mine as all the lights work, but took a look today and it don't look good. Insulation is cracked on the wires, there are two ground connections on the frame. I'm just going to replace all the wire from the plug on the tongue, right back to the tail lights, and make all my connections inside the trailer. I have butt connectors with heat shrink on them and solder inside them that melts when you put heat to it. Bob
03-22-2012, 03:00 PM
Sounds like a good plan. I'm curious how UHaul fished the wires from the tongue to where the wire exits underneath. It protects the wires nicely, but must have been a bear to fish.
03-22-2012, 05:45 PM
I thought about fishing my new wiring through the tongue, but decided not to. I'm afraid it would move around in there and chafe through, and there would be an unseen problem. Working on big trucks, that frequently happened where a wire that was loose in a inaccessible location would rub through and short out. Sometimes the only way to narrow down the trouble spot was to start cutting wires until the problem went away, then run new wiring in that area. Light problems were the most frequent tasks we did, especially here in the northeast in the winter. Keeping connections from corroding was near impossible, no matter what we did, but some methods lasted longer than others. If we couldn't make a connection inside out of the weather, it was best to leave it exposed where it could be found easily. I don't miss that work at all !!!! Bob
03-22-2012, 06:03 PM
........I'm afraid it would move around in there and chafe through, and there would be an unseen problem.......... Bob
Good point. Maybe why UHaul used the rubber jacketed wire.
