Uhaul swamp cooler - Butyl tape alternatives? - Fiberglass RV
Old 03-07-2012, 08:57 PM   #1
Mild temperatures here in upstate NY, and predicted for tomorrow too. So I decided to remove the swamp cooler in preparation for installing the Fantastic Fan tomorrow. That all went good, had to file a couple corners of the opening for the fan to drop in. Now I can't find butyl tape locally. I've read on here that is best to use for installation. Tried Lowes , Ace Hardware, and another local hardware/lumber yard. Half the people don't know what I'm talking about, the rest say they know of it but don't have it in their store. GRRRR!! Is there another name for it other than just "butyl tape"? Bob
Old 03-07-2012, 09:13 PM   #2
Butyl putty tape if you're looking for the stuff you can mold into a rope by running it with your hands .... or butyl rubber which is typically black "rubber' and requires a sharp knife to cut off the excess that hangs out. Not sure exactly what you're looking for.... have you check with an RV parts place?
Old 03-07-2012, 09:22 PM   #3
Trailer: Fiber Stream
Well, I see you're not near any Camping World stores.
Your closest Big City is Albany, so I googled "RV supplies near Albany, New York and found:
Albany RV
1101 Central Avenue
Albany, NY 12212-2309
1-800-426-9021
They list Butyl Tape on their online parts store.
RVone.com Parts Store Online Store
I'd call the Albany store and see if they have it in stock.
Old 03-07-2012, 09:36 PM   #4
Donna, I've never used it, but always see on here to "Don't use silicone, use butyl tape" so I figured OK that's what I'll do. The guys at Lowes really tried, but it seems it's another one of those simple requests that turns out to be not that simple.
Frederick, thanks for that info, I'm actually closer to Pittsfield MA, and there is an RV dealer there but not a very good one. Actually it's where we bought our Uhaul, and we almost got it for $1000 because they didn't know anything about it, BUT, then they did some online research and we ended up at $1800. still a good deal we think. Bob
Old 03-08-2012, 06:22 AM   #5
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
Bob, I chased around trying to find butyl tape, too. Finally found it at 2 RV dealers.
Old 03-08-2012, 11:38 AM   #6
Trailer: scamp 13
you can use plumbers putty tape in a spot like that. what your looking for is something that won't dry out and shrink . and that doesn't contain the demon sillycon
Old 03-08-2012, 04:26 PM   #7
I called a RV place in Hancock MA, it's about 40 minutes from me. They had the butyl tape so I went & got a roll 1 1/2" wide, $8. I had to grind down the fiberglass a little at the seam as there was a slight hump there. put on the tape, stuck the Fantastic fan in the hole, and ran the screws in with a cordless drill, and then hand tightened them. By using the drill, the screws will bore through the fiberglass. Then I smoothed the excess putty along the edge, and also used some to cover the screws. The directions say to seal the screw heads with silicone but I didn't dare do that! Picked up my tools, and then it started to rain, done just in time!! I still have to fit the inside trim piece to finish the job. One odd thing though, the swamp cooler was held on by 4 bolts from inside the trailer, but after I removed it there was a row of holes all the way around the opening as if there had been a standard vent there previously?? Thanks for all the advice. Bob
Old 03-08-2012, 04:30 PM   #8
Thomas G.'s Avatar
Originally Posted by mary and bob View Post
..........One odd thing though, the swamp cooler was held on by 4 bolts from inside the trailer, but after I removed it there was a row of holes all the way around the opening as if there had been a standard vent there previously?? Thanks for all the advice. Bob
I think the swamp cooler was a later upgrade. The instructions for installing it are in the repair manual. There is a vent shown in the parts manual that is different from the swamp cooler.
Old 03-08-2012, 07:34 PM   #9
Dicor Lap Sealant
501 LSW
Self Leveling Lap Sealant
Came with my Fantastic Fan and worked great
It is labeled for Industrial Use
Old 03-09-2012, 06:04 AM   #10
Raz
Raz's Avatar
Vermont
For future reference, try a building supply/lumber yard. That's where I found it. If they sell galvanized sheet metal roofing, butyl tape is used to seal the over lap between the sheets. Check the box the roll comes out of to be sure. It may be 1/2" instead of the 3/4" the RV store sells but it can be doubled up. After asking at numerous places and getting that clueless look I finally found a guy who knew what he was selling. Good luck, Raz
Old 03-09-2012, 06:42 AM   #11
Raz: one of the guys at Lowes mentioned the metal roofing stuff. The RV place I went to had just what I wanted. I had the Fantastic fan here way before I pulled out the swamp cooler, so I should have got the butyl tape sooner, but thought I could get it at Lowes. Then when it was so warm here Wednesday, I made a quick decision to pull out the swamp cooler and then couldn't get the tape without doing a 2 hour round trip. It all worked out in the end, and now I awake to a little snow on the ground this morning. Luck was with me again. Special thanks to Frederick for making me think of trying a RV dealer. I opted to go to one out in the country rather than have to do city driving, each one was about the same distance. We live outside a one stoplight village, so I don't care for city driving so much. Bob
Old 03-09-2012, 07:18 AM   #12
Raz
Raz's Avatar
Vermont
Bob, I bet you could go to 5 lumber yards, all having what you need, and if you didn't mention the metal roofing, they wouldn't know. Also it wouldn't suprize me if there is a different product that is also sold. Things change. Last year I went into a place and asked for a sheet of 1/2" particle board. The guy had no idea what I was after. All they sell Is MDFB.
Sounds like you got the job done. Great. Take care, Raz
Old 03-09-2012, 07:26 AM   #13
Thomas G.'s Avatar
........Things change.........
Good point. I was looking for butyl caulk (in a tube) and the guys at HD and Lowes looked at me like I had two heads. Used to be in the gutter and downspout section, but they have new stuff now.
Old 03-09-2012, 08:36 AM   #14
djtriceflt's Avatar
Trailer: 1985 U-Haul CT-13
Buytl Caulk in a tube
Tom,
I recently replaced the front CT window with bronze tinted Lexan and
needed butyl caulk in a tube. I discovered it available from 3M in a product called 'Window-Weld' super fast urethane in black. I don't know if it is available in white but I suspect it is. Great product but make sure you
keep the stuff off your fingers or you will be washing them for a week!
(lacquer thinner will get it off before it cures)
It's available at most autoparts stores and is actually just butyl which many of the new generation parts people know nothing about. I found out later it is much cheaper at Amazon or eBay if you get it free shipping...
don CT-13
"Sometimes the hunt is better than the catch"
djtriceflt is offline   Reply With Quote
uhaul
Butyl Tape ?? Harvey Problem Solving | Owners Helping Owners 18 09-08-2017 10:09 PM
Swamp Cooler Successes? Laurie Problem Solving | Owners Helping Owners 4 06-27-2009 01:02 PM
Butyl tape vs. butyl caulk- newbie looking for input Jason, M Problem Solving | Owners Helping Owners 9 08-11-2008 02:57 PM
Just Butyl Tape Or More ?? mitch Problem Solving | Owners Helping Owners 18 05-28-2007 08:20 PM
fantastic fan vs swamp cooler Al & Donna Care and Feeding of Molded Fiberglass Trailers 9 02-24-2007 11:44 AM
