Upgrading to two stage propane gas regulator - Fiberglass RV
Old 05-22-2015, 12:18 PM   #1
Courier 3.2's Avatar
Trailer: 2.3L Ford Courier Mini Motorhome Camper
First time propane refill and bad luck: gas siphoning from that bronze part on bottom (G800 LP Gas Marshall Gas Regulator). Looks like it is old way of two stage regulator. composing bronze one and standard one stage on top (see picture). So now I have decided to purchase new modern two stage regulator instead. Can I throw away that bronze one or I have to add it on bottom of my new two stage as well?
Courier 3.2 is offline   Reply With Quote
Old 05-22-2015, 12:42 PM   #2
When it comes to Gas, I go and ask a professional Gas person.
Old 05-22-2015, 12:55 PM   #3
In the lower provinces a 2 stage regulator connects directly to the LP lines and then to the appliances, but you may have different requirements in Canada.
As Darwin suggested, check with a local LP or RV service person.
Old 05-23-2015, 05:03 PM   #4
As you can see on picture above my OUT end of regulator is on top. All two stage regulators I can find so far have the Opening outlet located either on OUT side or for horizontal orientation. The regulators sat that the opening should be oriented vertically down. How critical is this requirement?
Old 05-23-2015, 05:06 PM   #5
As you can see on picture above my OUT end of regulator is _on top_. All two stage regulators I can find so far have the Opening outlet located either toward OUT side or for horizontal orientation. The instructions state that the opening should be oriented _vertically down_ which is impossible in my case. How critical is this requirement?
Old 05-23-2015, 05:18 PM   #6
Most often you do not get a second chance with Gas that is why you must be absolutely and positively sure your gas equipment and installation is correct. Please go and see a gas expert.
Old 05-23-2015, 05:28 PM   #7
What he said. Loud noises can ruin your day.
propane
Two stage LED's?? morgynm Electrical | Charging, Systems, Solar and Generators 18 08-10-2014 07:33 AM
Upgrading our water heater to work on gas and electricity peterh Modifications, Alterations and Updates 5 05-02-2009 11:36 PM
What signs that a gas regulator needs changing? TonyB Problem Solving | Owners Helping Owners 1 04-17-2009 06:47 PM
Canadian Tire 3 Stage Chargers Booker B. Problem Solving | Owners Helping Owners 13 03-29-2008 12:37 PM
Stage two Legacy Posts Modifications, Alterations and Updates 3 04-23-2003 06:28 PM
