Using bigger windows - Fiberglass RV
Old 12-05-2009, 06:42 PM   #1
Robert Johans's Avatar
Trailer: Nest Caravans
Compared to Scamp, some Perris Pacer's have extra wide windows. They look really good. Which got me thinking:
Can I replace my stock Scamp Hehr windows with a Hehr model that is wider? Is the integrity of the shell diminished?
Any thoughts or advice?
It would look something like this...
Old 12-05-2009, 08:19 PM   #2
james kent's Avatar
Trailer: Boler 1984
Go to the Home page and check out some of the similar trailers. The Cloud for example already has a larger window. The Egg Camper has a huge one.
Old 12-06-2009, 03:53 AM   #3
Raya's Avatar
Hi Robert,
I don't think you would have any shell integrity problems with a larger window like that, especially if you keep the vertical support (that is provided, to a certain extent, with the upper cabinet-metal support-lower cabinet).
Where you would run into an issue that would have to be resolved, is that the side windows (at least on Boler 13's) are tall enough that a wider window of the same height would run into the upper kitchen cabinets. OTOH, if you are willing to go with a shorter window (and fill the leftover hole where the original window had more height), or a shorter kitchen cabinet, you'd be good to go.
I think the newer style windows with a metal clamp ring do provide a bit of rigidity to the shell as well. Not that they are structural, of course. Also, one could easily improve upon the standard cabinet-brace-cabinet design, either with a beefier version, or with something else that does the same thing, structurally.
That wide window is a nice look, from the inside. For a while I toyed with the idea of moving my kitchen to the front so I'd have that big window over the kitchen counter.
Raya
Old 12-06-2009, 08:25 AM   #4
Thanks, Raya.
So that I am understanding you clearly, you're saying the tall (floor to ceiling) cabinet inside my door provides vertical structural support, as does the brace between my galley cabinet and its corresponding upper on the opposite side, n'est pas? And to remove either (without some substitute) would be a bad idea, presumably to prevent up and down deflection of the roof plane while traveling? Or to carry the weight of the upper shell?
I ask because I'm thinking of ways to make the "bed" larger and more comfortable for two. Right now that seems to mean modifying—if not the size, certainly the position—the vertical cabinet on the curbside and the galley opposite. My first thought was to replace the vertical unit with a desk-height cabinet and shift everything forward. But I think you're point is to preserve some floor to ceiling bracing.
Is that right?
Old 12-06-2009, 11:11 AM   #5
Trailer: Fiber Stream
Talking
...you're saying the tall (floor to ceiling) cabinet inside my door provides vertical structural support, as does the brace between my galley cabinet and its corresponding upper on the opposite side, n'est pas?
[b]I think you're point is to preserve some floor to ceiling bracing.
Is that right?
That's correct.
Old 12-06-2009, 01:43 PM   #6
Raya's Avatar
And to expand on it a bit more, what you are really trying to prevent is a change of shape. That is, the whole trailer getting wider and shorter. It's like a house in that there is more than one way to skin a cat (collar ties/rafter vs. structural ridge vs. etc.).
I think the closet does a pretty good job of keeping the shape on the door side (it could be better, of course). The upper cabinet/metal brace/lower cabinet support on the kitchen side is not quite as good at what it does, to my mind. There is room for improvement.
You could simply narrow the closet and kitchen by 6" and keep the supports as they are (but 6" further forward).
A couple of other ideas:
1) For the kitchen side, you could tab in a plywood "boomerang" to the wall (not quite boomerang shape, but hopefully that gives you the idea). The point there is that if the walls can't bow out, the roof can't sag down (unless there is a very heavy point load that sags the middle of the roof). This would be much stronger than what is there now, and could be tucked back a bit more toward the wall.
2) You could tab in a structural arch on the ceiling; say, where the bed meets the kitchen/closet.
3) You could make your "desk" open on only one side (say, toward the bed) and the front, and then make sure the wall on the other side is even more structural than it is.
Basically, if the roof can't sag, the walls can't bow out; and if the walls can't bow out, the roof can't sag. So you just need something that prevents either/or. Even light plywood (or other suitable material), if tabbed to the walls or ceiling, would be quite strong and reinforcing.
The thing is that fiberglass is actually a fairly "floppy" material. So you just have to account for that. A fiberglass boat is the same way. It's a mixture of "bulkheads," which are like walls tabbed to the hull, and partial bulkheads or (sort of) "knees" which are also tabbed to the hull but which give more openness. One difference is that on a boat you are trying to make the panels really strong even in the areas between supports*; whereas our campers aren't really heavy or strong enough for that, as built. The goal seems to have been lightness, affordability, and the ability to keep the basic shape; but not necessarily the ability to stand up to point loading.
I hope that made sense!
Raya
*Boats also have "stringers," which are like long shapes (think half circle) that run the length of the hull and are tabbed to it (you can literally use foam or hollow half rounds of plastic). The give quite a bit of "shape strength" to a hull, and help it to resist deformation ("oil canning") when plowing through the waves.
windows
Bigger would be better Jane Thomson Modifications, Alterations and Updates 9 12-14-2008 12:52 PM
A Bigger Bed forrybl Problem Solving | Owners Helping Owners 7 04-10-2008 09:23 PM
New T@DA, a bigger T@B Palmer M General Chat 30 07-05-2007 11:37 AM
I'd like a bigger Boler ! Dan Simon Wanted: Molded Fiberglass Travel Trailers 2 03-10-2006 06:37 PM
