Using Dometic refrigerator on 12 volts - Page 6 - Fiberglass RV
Old 01-15-2018, 09:32 PM   #101
Originally Posted by Raspy View Post
This is a very good plan. A common way to do it is with a Ford type, continuous duty relay, but I'm sure there are other good ones too.
We installed an isolator in our van a full size Chevy. The isolator was just a little silver canister about 3 inches tall and 1 1/2 to 2 inches across. It isolated the vehicle battery from the trailer battery so that they both charged but the vehicle battery couldn't be drained. We used a 30 amp fuse on it per the instructions that came with it. Very simple installation with the charge wire running to a 7 pin connector. The hot wire ran from a hot spot under the hood that was only hot when the engine ran. Full price was probably under $40 for isolator, fuse and wiring. We wired the entire 7 pin connector for charging, brakes and all lights. We used the color wires per the instructions. We put the brake controller in also. Really good instructions come with these things.
Old 01-15-2018, 10:24 PM   #102
Raspy's Avatar
Trailer: Roamer 1
Smith Valley, Nevada
Jann,
That sounds like a Ford style continuous duty relay. They are cheap, reliable and do the job very well. Only on when the TV ignition is on.
refrigerator
Casita refrigerator needs 12 volts charliej Problem Solving | Owners Helping Owners 41 12-05-2012 11:08 PM
Using refrig on 110 volts with no battery Mark J Problem Solving | Owners Helping Owners 9 07-02-2012 10:36 AM
Installing a digital Amps/Volts Meter peterh Modifications, Alterations and Updates 21 09-10-2009 03:37 PM
Problems with Refrigerator on 120 volts John Blair Problem Solving | Owners Helping Owners 14 05-07-2007 02:55 PM
12 Volts provider for testing Legacy Posts Modifications, Alterations and Updates 2 06-05-2003 09:52 PM
