Using Fastners instead of rivets - Fiberglass RV
Old 04-26-2019, 12:14 PM   #1
Trailer: SCAMP
Wisconsin
I have a 2005 13ft Scamp and I read awhile back that someone recommended using Stainless steel Fasteners because they last longer.
Can anyone steer me in the right direction?
Thanks
Echo 78 is offline   Reply With Quote
Old 04-26-2019, 12:23 PM   #2
Thanks
There's been a lot of noise about using SS bolts and nuts vs Rivets. The factory used rivets and that's good enough for me. SS is generally not much stronger than aluminum rivets but a lot more expensive. I modified the propane tank hold down using SS bolts, why SS? Because with they get bent I can brake them off and replace.
Old 04-26-2019, 04:19 PM   #3
I have never heard of anyone replacing a SS screw because it wallowed out it's mounting hole and was leaking.
I used all SS screws on my rebuild and have over 20,000 miles over the last three years and no leaks or loose screws.
redbarron55 is online now   Reply With Quote
Old 04-26-2019, 04:46 PM   #4
Tom Haberski's Avatar
Wisconsin
I've used Stainless steel and nylock nuts
Aluminum is not stronger in tension, compression or shear, all sizes being equal than S.S. The rivets are made of a pretty soft alloy....by design, so they can balloon out for fastening. This is an old topic, beaten to death on various fiberglass trailer forums and comes down to "use what you want".
Tom Haberski is offline   Reply With Quote
Old 04-27-2019, 12:56 AM   #5
I've got over 100,000 miles with factory aluminum rivets and no problems.
Old 04-27-2019, 06:47 AM   #6
Enjoy!
Old 04-27-2019, 10:27 AM   #7
When washing my Bigfoot for the first time I noticed the rivets for the front window cover were rusty. When it comes time to replace them I definitely won’t use a rivet with two different types of metal (ok, maybe stainless and aluminum would be a ok).
SnowballCamper is offline   Reply With Quote
Old 04-27-2019, 12:25 PM   #8
Name: Wayne & Barbara
Trailer: Parkliner
Iowa
Fasteners vs Rivets?
Well, rivets ARE fasteners.
Mostly y'all are talking Pop Rivets, which allow you to install them without needing to get to the inside. They come in steel and aluminum.
Screws are best if you want to be able to remove or reuse them.
Our former Scamp Deluxe had the wood cabinetry inside so screws we're appropriate.
The plastic caps got old a brittle over time. I bought a complete set from Scamp, and replaced the washers and caps with a dab of silicone under each. Do one at a time, so nothing shifts inside.
Old 04-30-2019, 09:44 AM   #9
Trailer: 1983 Casita & 1972 home-built
Dissimilar Metals Corrosion charts
This great paper on dissimilar metal corrosion has tables showing which fasteners are OK with which metal parts.
https://www.pdhonline.com/courses/s118/s118content.pdf
You can get stainless steel rivets, but have to be careful what other metals you use them with.
Stainless Steel Grades: This page has a great downloadable chart on the commonly used stainless steel grades and their uses. Note that not all stainless steel is suitable for marine use- if we camp or boat near the ocean much we need to pay attention to these details. The 316 series is best for marine uses, but most commonly available stainless steel hardware is not marine grade.
https://blog.mchoneind.com/blog/stai...l-grades-chart
Pressure Treated Wood: Another important aspect of dissimilar metal corrosion is that the most common pressure-treated wood chemicals are called Copper Quat (ACQ) and Copper Azole (CA) and they are extremely corrosive to galvanized steel hangers and fasteners. This is why we started seeing stainless steel joist hangers in the stores a few years back. The corrosion potential is so bad if you build a deck with ACQ pressure treated wood, you really should use marine grade stainless fasteners and design the deck structure so it does not depend on the continued existence of the joist hangers, nails, bolts, and other galvanized steel parts for structural integrity. Leaning against a railing nailed to a rim joist with galvanized steel fasteners is a dangerous act.
https://www.popularmechanics.com/hom...mber-15655848/
I started pulling coated decking screws out of my friend's 5 year-old pressure-treated wood deck with cedar deck boards and found they were already eaten half-through. This house is 10 miles from the Pacific coast. We bought marine stainless replacements and replaced every screw in the deck. It is expensive, but we can probably pull these screws and re-use them when the decking boards need to be replaced in a few years.
ARVZ is offline   Reply With Quote
Old 04-30-2019, 10:00 AM   #10
Rivets are fine until they get loose. There's no "tightening" them. I had mine loosen AND leak on my closet. They wallowed out, the rivets BENT... I replaced them with #10 SS screw/washer/nut. 3-4 yrs...no more problem. Obviously, this was in a stressful area on the body and that's why I replaced the alum. rivets. (2).
Old 04-30-2019, 06:20 PM   #11
Steve Hammel's Avatar
Trailer: Hymer Touring GT
Loon Lake Wa. and Boulder City, Nv.
I actually used both. I needed to replace some rivets and didn't have a rivet gun or rivets. I did have several packs of stainless nuts and bolts as well as several plastic rivet covers. It worked excellent and never had a problem. I do like to lock the threads with something like locktite.
Old 05-04-2019, 11:28 AM   #12
Question Why?
If a rivet needs replacing it is because it is being over stressed. Rivets should merely hold parts together not have to withstand stress. Airplane wing rivets never need replacing from stress. The permanent solution is to eliminate the stress.
Stephen_Albers is offline   Reply With Quote
Old 05-04-2019, 11:51 AM   #13
Another option nutzerts
Another option is to use nutzerts which are also called rivet nuts or anchor rivets. I have used them to replace screws that had loosened on a 1984 Bigfoot to hold the front canopy brackets in place. They come in aluminum or steel and are available at Princess Auto in Canada. This gives you a way of installing a nut on the inside of the fiberglass shell wall (from the outside) that is held in place, and then you can bolt through from the outside.
Greg in BC is offline   Reply With Quote
Old 05-04-2019, 12:41 PM   #14
Trailer: Designing and building
Thanks
I'll try.
First, for stainless fasteners, call Parker Merrick in Florida at 800-432-3700 or 954-761-1677. Tell them that Whitney referred you, might get preferential pricing. Expect to buy boxes of 25-100 pcs.
Now for the complicated part.
Riveted and bolted (screwed) joints are intended to perform in exactly the same manner; the fastener pulls the joined parts together with enough tension that the joined parts cannot move, and sprung tension in the fastener keeps the joint from developing play and wearing loose.
Blind/POP rivets* typically use compression in the joined materials to provide this tension. In soft materials, if the area under the head or under the bulbed shaft is too small this tension won't last long, and loosening and leaks will follow. They are an ideal fastener for initial assembly, but don't have an infinite lifespan.
Bolted joints typically use the fastener as a sprung element, but that isn't practical in the case of thin fiberglass/wood structures, so the bolted assembly is once again the spring. When I through-bolt as we're discussing, I will typically use neoprene-bonded sealing washers on the outside, with either truss head or countersunk oval head** screws, metric fender washers to fit, and nylon-insert lock nuts. The neo-bonded washers are slightly conical, and between that and the rubber layer there's a pretty strong spring force. The metric fender washers are thicker than US standard, and don't sink into fiberglass or wood easily.
Bolted joints tend to hold up longer, seal better, can be retightened, and can be maintained. Riveted joints are quicker and a little less expensive, but don't last as long.
Complicated enough? :-)
*If you're going to use blind rivets, seek out "closed-end", which won't need to have the mandrel hole sealed to avoid leakage.
**Neo-bonded washers are a metal roofing or metal building fastener, if your local supplier has no idea what they are. If you want a larger washer and a very clean look, use oval head screws with a neo-bonded washer that the screw head sits down into. This won't be the "correct" size, but between head fill and gasket compression it works very well.
Next we can do bonded joints!!
Thomcat316 is offline   Reply With Quote
Using a MobiCool instead of the fridge. drdog Problem Solving | Owners Helping Owners 0 07-06-2015 01:39 AM
Nuts n' bolts instead of rivets? dylanear Modifications, Alterations and Updates 20 05-31-2012 01:57 PM
Need a tool for mid 70's window fastners Peter_Crowl Problem Solving | Owners Helping Owners 6 01-03-2011 09:04 AM
ss fastners Jason Goward Problem Solving | Owners Helping Owners 2 08-22-2007 03:09 PM
Scamp Mattress Instead of Cushions Kimberly Geddes Problem Solving | Owners Helping Owners 6 06-14-2006 09:08 AM
