Using HVAC tape on Reflectix - Fiberglass RV
Old 06-22-2014, 07:13 PM   #1
AM Moats's Avatar
Trailer: 13' Scamp
I'm working to put up Reflectix on the bare walls of my Scamp. Once I'm done with that I'll cover it with a marine hull liner. Based on input from some other threads, I decided to use 3M 90 Adhesive Spray and to cover the seams of the Reflectix with HVAC tape before applying the hull liner (with more 3M 90). Now that I have the HVAC tape on the seams, I'm becoming concerned that the tape won't hold well enough once I apply the hull liner. Would you use the HVAC tape?
AM Moats is offline   Reply With Quote
Old 06-23-2014, 02:00 PM   #2
Trailer: Burro
Massachusetts
As long as this HVAC tape is the aluminum film type with peel away protection over the sticky side, you should be OK. I have used this stuff on many non-duct applications and is is great stuff. It sticks incredibly to any smooth surface and resists moisture very well.
rick.a is offline   Reply With Quote
Butyl tape - putty tape? Janb313 Problem Solving | Owners Helping Owners 10 03-23-2013 10:21 PM
gas heater overhaul - RV shop or HVAC shop? jack maloney Care and Feeding of Molded Fiberglass Trailers 1 04-20-2008 01:58 PM
Reflectix needed Bonnie Classified Archives 6 04-17-2008 07:17 PM
Add Reflectix Under Mattress Pete Dumbleton Modifications, Alterations and Updates 0 04-16-2008 10:36 PM
Using Butyl tape Gary Little Problem Solving | Owners Helping Owners 2 03-01-2006 08:34 PM
