Using Toilet After Winterizing - Fiberglass RV
Old 10-10-2014, 05:05 PM   #1
Trailer: ParkLiner
Virginia
I'm heading South probably in January.
I'm thinking I need to winterize (in Virginia) by Mid December at the latest. So I'm wondering if there is a way to use the toilet after winterizing. Could I just pour some water in the toilet to flush and then follow with a little antifreeze (macerator)?
Hopefully, the temperature will be above freezing where I am headed, so I can flush everything when I get there. I am only talking about using the toilet for 2 or 3 days on the trip down.
Huck is offline   Reply With Quote
Old 10-10-2014, 06:12 PM   #2
I think you would be fine by adding a bit of antifreeze and if you are using it at night on the way the trailer will be warm.
Old 10-10-2014, 06:32 PM   #3
CPW
CPW's Avatar
Trailer: 2015 Escape 5.0TA
I am understanding that you will be sleeping in the trailer at night and want to use the toilet during overnights on the southward voyage (rest areas and food/gas stops suffice for daytime relief). If it were me, I would put some antifreeze in the black water tank and flush with water. Then dump and operate as you would in warm weather if it is warm at your destination. We sometimes carry a couple of Arizona Tea gallon jugs to use for "emergency" flushing. Depending upon where you are going, and if you are staying until winter ends, you may not have to winterize before heading back home. Living in Florida, I have never winterized my campers. The coldest I have ever seen is 31 degrees for a couple of hours before sunrise. I have a carport in which I can aim a ceramic heater under the camper, and a thermo-cube that turns it on at 33 degrees. Just blowing a little heated air under the trailer keeps the temperature in the carport above freezing, but the temps typically don't get that low. In February, at Scamp Camp in Sebring people often wear T-shirts during the day, or a sweat shirt if it's cool. I do, however, drain the water heater when I don't think I will use the camper for an extended period of time during the "winter" months.
Storing Toilet Paper Roll in Toilet-Shower Combo S Sato Plumbing | Systems and Fixtures 24 04-18-2015 12:46 PM
Using scuba tank for blowout winterizing? JohnF Care and Feeding of Molded Fiberglass Trailers 12 02-02-2012 06:46 AM
Winterizing Aid Steve L. Modifications, Alterations and Updates 1 04-26-2009 03:03 PM
Winterizing and LCD Screens Pete Dumbleton Care and Feeding of Molded Fiberglass Trailers 4 03-04-2009 01:46 PM
Replace old toilet or go portable toilet Paddy Morris Plumbing | Systems and Fixtures 7 04-25-2006 06:17 PM
