utilities access question - Fiberglass RV
Old 01-14-2013, 01:02 PM   #1
Kjs
Trailer: Shopping
As I am considering buying a molded fiberglass travel trailer, probably a bigfoot, maybe another brand depending on availabilty in my area, a question came to mind. Since these units are totally enclosed in fiberglass, how does one fix utility problems that may occur under the floor. In a stick built trailer, your water lines, wiring and drain lines are easily accessed by cutting through the crappy tyvek type materieal they staple underneath. Can any of you who own one of these molded fiberglass trailers tell me how you access these things if need be. I am hoping to not hear, cut out the floor. Thanks for any input.
Kjs is offline   Reply With Quote
Old 01-14-2013, 03:59 PM   #2
Trailer: 28' Bigfoot Silver Cloud
Oak Park, IL
Generally all of these water lines and power wires can be accessed through closets, benchseats, etc. On our UHaul, you can remove the benchseat cover and have access to almost everything. The closet also unscrews, as does the sink cabinet in the bathroom. There is nothing that I haven't been able to reach, but sometimes it takes a bit of flexibility! Everything is above the floor and internal except for the drain outlets.
OK, that's for the UHaul. Hopefully others will chime in about Bigfoots and other trailers.
Old 01-14-2013, 04:07 PM   #3
Brian Van Snell's Avatar
Trailer: Escape 13 ft 2010 ('Ladybug') / 2003 Subaru Forester/ 2012 Toyota Highlander
Here is a link to our trailer, an Escape 13, while it was being built. As Kevin said, a lot of the plumbing, wiring etc. can be accessed from the cabinets.
Progress Jan 22 | Flickr - Photo Sharing!
Brian & Maria
2010 Escape 13 "Ladybug"|2003 Subaru Forester|2012 Toyota Highlander
Brian Van Snell is offline   Reply With Quote
Old 01-14-2013, 05:22 PM   #4
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
There isn't much of anyplace to "hide" things in these trailers, since most are single-wall construction- and even those with "double shells" have had all the plumbing/wiring added after molding, so nothing's hidden in the build process.
As already noted, most plumbing/wiring is easily accessible from inside the trailer's cabinets etc.
Francesca
Old 01-14-2013, 09:58 PM   #5
cpaharley2008's Avatar
Everything is accessible from inside or access doors, no cutting from outside is needed.
Old 01-15-2013, 05:46 PM   #6
Kjs
Trailer: Shopping
Thanks for your replies and answers. Hopefully bigfoots are the same as I am looking for a winter package. Do any of you know of any other fiberglass manufactures that sell a well insulated trailer with double pain windows that I should be looking at?
Old 01-15-2013, 06:16 PM   #7
I think that Oliver has those features...they only made about fifty before they closed up shop, but there's one-maybe two- for sale right now at
Molded Fiberglass Trailers | Fiberglass RV's For Sale
Francesca
Old 01-15-2013, 06:21 PM   #8
Escape Trailers offer dual pane windows and heated insulated tanks and extra insulation and they are still in business.
Need an Access Door Harvey Problem Solving | Owners Helping Owners 14 02-24-2011 07:03 PM
Access doors Bobbie Mayer Problem Solving | Owners Helping Owners 7 11-15-2007 04:15 PM
Cable Access Legacy Posts Problem Solving | Owners Helping Owners 4 12-04-2002 03:32 PM
