Valterra Hand Pump bypass ? - Fiberglass RV
Old 09-04-2018, 12:02 PM   #1
Trailer: 13 ft Scamp
Hello, I have a Valterra hand pump in my Scamp and wanted to install a 12V pump and plum into the valterra so I can use either hand pump it or turn on a switch and have it pump water. Is there a way to do this ? I dont mind using the hand pump for hand washing or short time use but would be nice to bypass it when I wanted to use more water without having to pump -- all coming through the valterra faucet.
Any advice/ideas/suggestions/etc highly appreciated!
Thanks!
Andy
andy vaughan is offline   Reply With Quote
Old 09-04-2018, 12:34 PM   #2
Civilguy's Avatar
Puget Sound, WA
Thanks!
Andy
Andy,
Looking at the Valterra hand pump and its repair kit online, my answer is "possibly, but I have my doubts and also some additional concerns".
If you were to install an electric pump inline below the Valterra, I believe that the hand pump would still work based on my experience with a Flojet and seeing how that pump is constructed and operates. Basically, the Valterra would just need to overcome the electric pump's check valves. I think that part would work just fine.
My primary question would be whether the electric pump could or should pump "through" the Valterra. For that answer, I suggest contacting Valterra.
An alternative approach to evaluate this would be to hook a pressurized water supply to the Valterra inlet to see if the pressurized water bypasses the pump. You could do this with a household water supply, but you might be risking damaging the Valterra with the pressure causing the Valterra to crack or leak. So, I think contacting Valterra first would be a good approach.
If you are considering leaving the Valterra in-line primarily to accomplish better water conservation than what you think you might achieve with an electric pump, you might look at this thread which includes the positive experience I had with a low-flow Danco aerator.
lower flow faucet and shower head
~ "This post is a natural product. Slight variations in spelling and grammar enhance its individual character and beauty and are in no way to be considered flaws or defects." ~
New hand pump faucet- valterra rocket or whale V or... Zennifer Plumbing | Systems and Fixtures 5 06-01-2016 01:46 PM
Pump Bypass - required? glamourpets Modifications, Alterations and Updates 6 06-17-2014 01:36 PM
broken hand water pump cyndi H Problem Solving | Owners Helping Owners 21 10-21-2008 05:58 AM
Hand Pump Water Fixture Brian T Problem Solving | Owners Helping Owners 1 05-28-2007 05:36 AM
hand pump faucet lost it's prime, What's easy way to prime it? Curtis F. Problem Solving | Owners Helping Owners 16 04-10-2007 05:00 PM
