Vents: where oh where to find them? - Fiberglass RV
Old 04-28-2016, 07:05 AM   #1
Trailer: 1975 Boler
Quebec
My restoration project is moving along. Aunt Cereal said that next time I consider a big project like that, she's coming along and block me with her veto!
Pics will come eventually...
I need a 9.25" x 9.25" vent for the heater and a 18" high x 22" long vent behind the fridge. These vents are nowhere to be found. My best bet at this point is to have someone make them custom. Any ideas?
Thanks!
Uncle Cereal is offline   Reply With Quote
Old 04-28-2016, 07:50 AM   #2
Johnny M's Avatar
Deep South
Try Home Depot or Lowe's and look at their soffit vents. I used them for my Boler reno on the a/c and fridge, they only were a couple of dollars each, have holes for screws or rivets and worked well with butyl tape for a good seal.
Old 04-28-2016, 08:01 AM   #3
Trailer: 77 Scamp 13
My fridge vent is nearly identical to soffit vents for wood soffits. Original equipment. Might try the scamp store too. Or vintage trailers.
Old 04-28-2016, 11:19 AM   #4
Trailer: 1975 Boler
Quebec
Didn't find them online: Home Depot, Vintage Trailer Supply, etc. I talk to a friend who makes heating ducts: none of their suppliers carry those dimensions.
Old 04-29-2016, 02:49 PM   #5
Roy in TO's Avatar
I found one for the furnace at a Home Hardware a few years back. Stock item but had to be ordered in.
Restoring Our 1972 Boler American
Product #RG0569 can be found on pg 15 of this document:
http://www.imperialgroup.ca/userfile...%202013%29.pdf
Old 04-29-2016, 04:48 PM   #6
Trailer: 1975 Boler
Quebec
That's 8"x8". I might have to use that if I don't find the right dimensions... Thanks!
Old 05-03-2016, 07:14 AM   #7
Trailer: 1975 Boler
Quebec
It's actually 8"X22", not 18X22... Same problem: I don't find anything that's 22" long!
Old 05-03-2016, 08:08 AM   #8
Trailer: 1975 Boler
Quebec
Answer from Imperial Group:
"No, we do not have this type of product. All we have that resembles this product is our side wall grills not designed for your application. All our products are designed for indoor use only."
Old 05-03-2016, 09:06 PM   #9
Roy in TO's Avatar
Sandblast, prime, then coat with Tremclad "recreational white" - Imperial group will never know what happened to their product.
Then again, it is a furnace vent.
Old 05-03-2016, 09:27 PM   #10
Roy in TO's Avatar
I need a ... 18" high x 22" long vent behind the fridge. These vents are nowhere to be found.
A post by Gilles in another thread lead me to this vent:
Refrigerator Vent Metal | coleman pop up parts
Checking back to this thread, I realized it was only 1/2 the height that you wanted. Then I thought you could use 2 behind the fridge.
Then I remembered a number of posts on fridge venting and wondered why you would need a vent that big. I doubt I have the same fridge as you, but you can see what and why I did in this thread:
Improving fridge venting
And once again, I used some of those Imperial interior Vents.
Old 05-04-2016, 03:15 AM   #11
Here is the link to the 8" x 22" vent cover you are looking for. It is bad illustration of the part but it is the right one for your needs. Too bad I tossed out one I had that size when I remodeled my vintage Sunrader motorhome.
8" x 22" UPPER REFRIG VEN
Old 05-04-2016, 03:45 AM   #12
Thanks!
The smaller vent for the furnace. I don't have a Boler but my investigation of the furnace(s) they were using in that era indicated that they were made by Suburban. Try to get the model number and then go into the files for this forum and look for a parts diagram. That will give you a part number. Then contact this person and see if he has a vintage furnace or two around that he is using to salvage parts from. If he does not I would suggest creating some automatic searches on craigslist in the RV section for that model number. Here in Seattle I frequently see vintage RV furnaces show up when people are parting out old travel trailers and campers of that 1970 era. They don't sell for a lot of money
Suburban Furnace - Heater - Stove PARTS - Suburban Furnace Parts Source
Old 05-04-2016, 09:27 AM   #13
Joe MacDonald's Avatar
try:RV Doctor George - Parts
Joe
Old 05-04-2016, 11:15 AM   #14
Sylvio,
I am in the process of installing a larger Dometic refrigerator in my “83 Scamp and bought a brand new Dometic 123A upper vent on E-bay about a month ago. It is 8.5” x 21” and has never been installed. Photos below.
I taped it to the opening during the snow storms we had in Denver the last two weeks to keep the snow out. However, I found that since the new vent opening is above the belly band, it tilts back a little and the openings allow the snow to blow in the back of the frig. Not good, so I have to install the newer model of upper vent that is deeper and diverts the water back out.
If you are still in need of one, it’s yours for $25 including shipping. You can use Paypal, personal check or whatever works for you since the vent is of little use to me. I can't help you with the other panel though.
If you want it, just PM me with the shipping information.
Jim
Scamper Jim is online now   Reply With Quote
Need Door hinges or at least where to find them? Kathy Provost Problem Solving | Owners Helping Owners 4 06-01-2010 10:23 PM
New towel rails won't kink or bend if you bump into them. peterh Modifications, Alterations and Updates 1 04-21-2008 06:53 AM
Do you know them? Ericpa3 General Chat 0 01-28-2007 12:58 PM
cabinet doors, Do we replace them? Ryan Kennelly Modifications, Alterations and Updates 26 05-29-2006 08:45 AM
What Would You Like Them to Say? Nancy in Oregon Jokes, Stories & Tall Tales 1 12-17-2005 07:47 PM
