VIN location - Fiberglass RV
Old 03-29-2009, 11:28 AM   #1
Isaac M's Avatar
Trailer: 1988 19 ft Scamp
Hi All,
Can someone with an older (70's) 13' Scamp let me know where the VIN tag is normally located on the trailer?
Thanks!
-Isaac
Isaac M is offline   Reply With Quote
Old 03-29-2009, 02:02 PM   #2
Pete Dumbleton's Avatar
There is a label with VIN, perhaps fictional weight and GVWR or GAWR located on the vertical inside surface of the curbside A-frame not far back from the coupler, but it may have been damaged or painted over. The GxWR will be a large clue to the "rubbering" capacity of the original axle (In '70s, likely 1,200 lbs).
The VIN is stamped on top of that frame member just a inches back from the coupler but may be hard to spot under the paint (I presume they stamp, then paint).
One way I found to see it is in shade or dark, using a flashlight to shine across/along the top surface of the beam to get some contrasting shadows.
You may have to remove some paint to read the entire number.
There should also be a metal tag on the axle beam denoting the capacity, plant where built and the serial numbers -- If you obtain those numbers, ID the factory from the Dexter site, call them and ask for the 'Keeper of As-Built Axle Records' , you can get all the original specs and measurements, bracket options, brake flanges, etc., for the original axle, which will all be of great assistance in replacing the existing axle should that day come, which likely won't be long if the axle is original -- The '70s were a long time ago in axle-years!
Old 03-29-2009, 03:34 PM   #3
Dan Meyer's Avatar
You can see a picture of what Pete is talking about on my web site
http://scamp.n0kfb.org/VIN_Decoding/scamp-vin_.jpg
-- Dan Meyer
Old 03-29-2009, 10:03 PM   #4
Isaac M's Avatar
Thanks for the quick response and the picture. I'll do some checking in some different lighting conditions.
-Isaac
license, registration, title, vin
AC location William L. Care and Feeding of Molded Fiberglass Trailers 8 10-08-2008 12:13 PM
Battery location Dan Simon Modifications, Alterations and Updates 39 05-27-2006 10:22 AM
Add Your Name & Location Nancy in Oregon General Chat 13 04-25-2006 07:30 PM
AC location William L. Modifications, Alterations and Updates 0 01-01-1970 12:00 AM
