Wagon Master Furnace issues - Fiberglass RV
Old 06-04-2017, 05:18 PM   #1
fidgetboy's Avatar
Trailer: Boler 13' 1973
I have a Wagon master furnace model 5000-f. The unit used to work great but now I am running into the issue of when I transfer from pilot light to ON it will go out after a few minutes. If I leave it on pilot it runs no problem. Unsure of how to proceed I have cleaned the thermo coupler with steel wool and no change. Any advice is appreciated.
ID:	106976Click image for larger version
fidgetboy is offline   Reply With Quote
Old 06-05-2017, 12:19 PM   #2
Trailer: Sprinter 'til I buy
Denver, CO
It sounds like a bad thermocouple. The only part that doesn't seem normal is that a bad thermocouple won't usually hold the pilot light on either. Get a 2nd opinion, but a thermocouple is inexpensive. Your RV furnace may differ from home furnaces. If your heating season is over, you could wait until fall.
Tom 72 is offline   Reply With Quote
Old 06-05-2017, 11:21 PM   #3
fidgetboy's Avatar
I picked one up today with that in mind will change out soon. Only $13.00 so worth a shot.
Old 06-11-2017, 02:12 PM   #4
fidgetboy's Avatar
Update thermal couple replace and furnace now appears to be working well. Thanks all
Old 01-15-2018, 03:24 PM   #5
Hi Jason
Where did you get the Thermal Couple?
Elvin
omache27 is offline   Reply With Quote
Old 01-15-2018, 03:57 PM   #6
thermo couple
take the old one out go to your nearest competent hardware store they should have it nothing complicated about them.
I just did a rebuild of a 30 year old Vermont castings gas stove I used amazon for all my parts including a new gas valve and thermocouple!
be thankful if its just a thermocouple and they do go bad!!
bob
Old 01-15-2018, 06:06 PM   #7
Thanks Bob - I'll try some local hardware stores.
Elvin
Old 01-15-2018, 06:29 PM   #8
Trailer: Boler 13 ft
just be careful not to bend the tube to much to kink it when installing new one.
Old 01-15-2018, 07:11 PM   #9
Mike Magee's Avatar
Trailer: 93 Burro 17 ft
Or an RV dealer should have them, too.
furnace
Wagon Master heater temp control doesn't shut off burner. PumpkinBoler Problem Solving | Owners Helping Owners 4 06-11-2017 02:14 PM
Wagon-Master 6000B furnace Rick G Problem Solving | Owners Helping Owners 9 08-24-2014 07:29 PM
Wagon Master Furnace Dave Mc Classified Archives 17 06-08-2009 08:02 PM
