Wagon Master heater temp control doesn't shut off burner. - Fiberglass RV
Go Back   Fiberglass RV > Maintenance | Restoration | Modifications | Problem Solving > Problem Solving | Owners Helping Owners
Click Here to Login
Old 09-21-2014, 04:43 PM   #1
My Wagon Master furnace had the temperature control sensor mounted below the furnace at the floor causing the burner to run continuously.
This must be a common problem with gravity furnaces specially when someone with no experience installs a used one with no instructions and not a whole lot of brains.
The external (outside the firebox) thermocouple must be positioned part way up the furnace burner box as it regulates the temperature of the burner box so the temperature of the exhaust does not exceed safe levels. This will cause the furnace to cycle hence limiting the overall BTU output of the furnace.
Took an afternoon of tinkering but it now has the Fire box thermocouple mounted securely in the right location and it works great.
PumpkinBoler is offline   Reply With Quote
Wagon Master heater temp control doesn't shut off burner. PumpkinBoler Problem Solving | Owners Helping Owners 4 06-11-2017 02:14 PM
Wagon-Master 6000B furnace Rick G Problem Solving | Owners Helping Owners 9 08-24-2014 07:29 PM
Shut off valve no shut off!! Tamid Plumbing | Systems and Fixtures 11 06-06-2012 02:55 AM
Toilet doesn't shut off completely ThomasE Plumbing | Systems and Fixtures 4 05-14-2011 09:47 PM
Wagon Master Furnace Dave Mc Classified Archives 17 06-08-2009 08:02 PM
» Trailer Showcase
Terragrin
Air Doug
2017
Mfrost
