Wagon Master heater temp control doesn't shut off burner. - Fiberglass RV
Old 09-10-2014, 06:17 PM   #1
My furnace burner wont shut down when the ambient temperature gets up to the selected number on the dial. I heated the copper tube (below the heater) that is the temperature sensor to 90 degrees fahrenheit and the burner still did not shut down. What would cause this to happen and how do I fix it.
I did clean and inspect the heater for rust out and cracks by removing it from the trailer and dismantling it. The burner would not light to begin with as the orifice was plugged. Burner lights fine and flame is good. The pilot has always worked fine.
PumpkinBoler is offline   Reply With Quote
Old 09-10-2014, 07:57 PM   #2
Roy in TO's Avatar
There is no direct corelation between the number and temperature. We find on our wagonmaster that it cycles at a comfortable range up to about 2 1/2 after that it pretty much stays on all the time.
Does yours cycle at the lower numbers on the dial?
Old 09-11-2014, 06:07 AM   #3
It will not cycle at any setting.
I think the temp sensor is supposed to be up beside the flame box as in a partial photo that I saw showed the temp sensor wire or tube heading toward the top not through a hole and mounted below the heater where it will only get cold air. Temp sensor in the picture was clearly not below the unit. Moving the temp sensor up higher gives me something to try on the bench in the garage.
Old 07-16-2016, 02:12 PM   #4
Trailer: boler
Boler furnace temp control
Any update on this? I've been having the same issue, and my furnace also has the small tubing sitting outside of the metal box of the furnace.
Cheech00TS is offline   Reply With Quote
Old 06-11-2017, 02:14 PM   #5
fidgetboy's Avatar
Trailer: Boler 13' 1973
Mine is this way too. Any updates?
fidgetboy is offline   Reply With Quote
Wagon-Master 6000B furnace Rick G Problem Solving | Owners Helping Owners 9 08-24-2014 07:29 PM
For Sale: Original - Boler/Trillium Wagon Master Propane Furnace Kurt in BC Parts: Buy | Sell | Trade 4 11-05-2013 09:14 AM
Shut off valve no shut off!! Tamid Plumbing | Systems and Fixtures 11 06-06-2012 02:55 AM
Toilet doesn't shut off completely ThomasE Plumbing | Systems and Fixtures 4 05-14-2011 09:47 PM
Wagon Master Furnace Dave Mc Classified Archives 17 06-08-2009 08:02 PM
