Wall covering under or up to rubber window gasket? - Fiberglass RV
Old 05-30-2015, 08:08 AM   #1
Trailer: Scamp - The Haunted Mansion
As we get closer to that point on our rebuild, I'm wondering if the rat fur/reflectix combo is meant to go under the rubber gasket on the front window of the Scamp or up to it? When we pulled the old window out, the original ensolite was under it...but it sure seemed a lot thinner than the reflectix/headliner combo.
If it goes on before the window, will I run into trouble getting the gasket to seal? Or should I just leave the last little bit free until the window is in, and then shove it under the gasket with a plastic putty knife after the fact?
Thoughts? Suggestions? Thanks!
- Tony
Sohkraites is offline   Reply With Quote
Old 05-31-2015, 10:02 AM   #2
ckayaker's Avatar
Trailer: Trillium 4500
I'm not exactly sure what you are suggesting, but I can tell you that when I redid my windows instead of hiding the wood frame between the Ensolite and the outer fiberglass, I decided to make the wood visible, more like house windows. I rabitted out a small channel for the Ensolite to be tucked under and held in place by the wood frame so it looks neat. No issues so far since doing this a couple of years ago. I like the look as well..
ckayaker is offline   Reply With Quote
Window Gasket, Window Seal, Window Molding D Shubel Problem Solving | Owners Helping Owners 9 05-16-2011 04:30 PM
Scamp 13 wall covering Greg G. Care and Feeding of Molded Fiberglass Trailers 11 10-16-2010 02:36 PM
Wall covering on Lil' Bigfoot Peter DBK Care and Feeding of Molded Fiberglass Trailers 6 06-07-2010 06:53 PM
Captain (mold) need advice for wall covering and floor pls Elizabeth.G. Problem Solving | Owners Helping Owners 1 05-19-2009 03:05 PM
wall covering on trillium Lee Trenholm Problem Solving | Owners Helping Owners 21 05-27-2008 01:24 AM
