Waste Termination - No Holding Tank - Fiberglass RV
Old 05-28-2013, 11:25 PM   #1
Trailer: Casita 2001 spirit
My 2001 16' Casita Spirit has a a broken 1-1/2" pipe roadside under the frame. My fix is to saw a clean cut, add a coupling then a new 1-1/2 piece up to where the smashed pipe hanger is (I have a new hanger) then add a slip elbow, 1-1/2" nipple & the 1-1/2 fitting w/blk cap w/3/4" M garden hose thread which I got from the factory.
I want to have the last fitting w/hose thread at a right angle to the Casita frame, not parallel to the frame.
Am I on the right fix here? (this is not in the A-Z book)
Thanks,
Elaine
(camped in the driveway)
partslady9 is offline   Reply With Quote
Old 05-29-2013, 06:52 AM   #2
cpaharley2008's Avatar
pictures will help....
Old 05-29-2013, 07:45 AM   #3
Trailer: 2014 Escape 21, Lil Joe
Elaine
I think I know what you are trying to do. I would add a valve in the line so any trap/trapped water won't rush out when you take the cap off to connect the hose. I switched from PVC (white) to ABS (black) pipe at the slip fitting. I added a 1.5" rv slide valve and a 1.5" to 3" rv sewer fitting. Then used a 3" RV sewer cap with a hose fitting. That way you can either use a 3" sewer hose or 3/4" gray water hose to dump with.
Eddie
Old 05-29-2013, 05:03 PM   #4
Great idea about adding the valve. You folks are always so helpful. I'll work on trying to get some pictures. Think my neighbor can help me with the photos-not my thing.
Thanks much.
Elaine
Old 05-30-2013, 01:39 AM   #5
Valve on order
Love that Amazon prime - should get the part by Friday. We are going to Santa Marie for rodeo hauling the parade car - Drat more lost trailer work time but the weekend should be fun.
Thanks again,
Elaine
Moving Black Waste Tank Don A Plumbing | Systems and Fixtures 2 10-25-2010 05:12 PM
1978 Boler Waste Tank Leaks Errol Holbrooke Problem Solving | Owners Helping Owners 0 08-29-2010 03:02 PM
Holding Tank Chemicals Pete Dumbleton Problem Solving | Owners Helping Owners 10 01-17-2008 06:42 PM
holding Tank Oders Legacy Posts Modifications, Alterations and Updates 10 07-21-2003 04:17 AM
holding tank antifreeze? Legacy Posts Problem Solving | Owners Helping Owners 6 02-17-2003 11:43 AM
