Water Damage Help - Fiberglass RV
Old 01-14-2020, 04:27 PM   #1
Trailer: Ford Fleetwood
Water Damage Help
I found this large water damage hole in my rv wall recently and I'm wondering what the best plan of attack is to fix it? I've fixed the leak that caused the damage. The previous owner took most of the damaged wood and insulation but it still looks atrocious. Its right down to the fiberglass exterior as well.
00pipirose is offline   Reply With Quote
Old 01-14-2020, 06:06 PM   #2
This is not the best forum for you to find help in, the members here are owners of molded fiberglass trailers. Your RV has a very different method of construction than the ones we own.
But of course no one wants you to go away without at least some clue of where you can go to find others who also own the same make and style of RV you have. So here is a link to the Ford Fleetwood Owner's forum.
Fleetwood Owner's Forum - iRV2 Forums
Wishing you the best results with your repairs.
Old 01-15-2020, 11:32 AM   #3
Trailer: boler
this works on water stained stipple in a house so it may work for you,mis 50% water and household bleach put in a spray bottle and apply lightly DO NOT SATURATE repeat after giving it lots of time to dry if needed, works on water stained fabric also,,,,,but remember if possible test on an area of the fabric ( or what ever ) on a site that will not show
artichoke is offline   Reply With Quote
Old 01-15-2020, 11:33 AM   #4
Trailer: Trail Cruiser
Been there, done that.
I suggest removing the window and them the damaged panel(s). Try to remove them in one piece if possible so you can use them as a template for the new panel.
If it is a stick frame remove any damaged studs or at least the damaged portions and replace with new. If you only replace the damaged portion of the stud, run a new piece adjacent to the portion you replace extending at least a foot to the solid portion you left in place. Glue the overlapping areas of the studs and secure with wood screws extending through both. Cut replacement panel and attach to studs. Reinstall window making sure it is well sealed. Good luck!
Buying FBTT and Water Damage/ Trailer Frame? Anne in NW Care and Feeding of Molded Fiberglass Trailers 5 10-17-2013 12:17 PM
water damage GerthT Problem Solving | Owners Helping Owners 4 04-25-2012 11:34 AM
Water Damage advice needed Rusty B Problem Solving | Owners Helping Owners 4 02-23-2012 06:45 PM
Does this look like water damage? Rebecca H. Problem Solving | Owners Helping Owners 14 07-16-2007 11:14 PM
5th wheel bathroom water damage Paul and Libby Smith Problem Solving | Owners Helping Owners 2 09-19-2006 06:45 AM
