water dripping from range hood - Fiberglass RV
Old 06-05-2011, 02:10 PM   #1
Trailer: 2012 Escape 19
I searched the forum, but didn't see anything ... we've got water dripping from the back of the range hood onto the counter space behind the sink/stove and can't figure out where it's coming in (Casita 17' SD). The outside vent looks good, but i haven't tested it for leaks as it's still raining. Has anyone else experienced this? Can anyone give some guidance as to where to look for the leak other than the outside vent?
thanks so much,
Jane
2012 Escape 19
New to us in May 2014
JaneM. is offline   Reply With Quote
Old 06-05-2011, 02:51 PM   #2
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
Hi, Jane!
Is it dripping when you've been cooking, or only after a rain?
I ask because stove burners make a lot of water vapor, easily enough to create the effect you describe...
Other than that, I'm not familiar with Casitas, but I'm sure that someone that is will chime in before long
Francesca
Old 06-05-2011, 09:02 PM   #3
Doug P.'s Avatar
Trailer: Escape 5.0TA
Southern Alberta
Is the vent riveted on, if so make sure the rivets a caulked so water doesn't leak through them.
Doug P. is offline   Reply With Quote
Old 06-06-2011, 12:30 PM   #4
It's leaking while it's raining - and it's quite a bit of water. I don't see any rivets, but I went over this morning and it's possible the caulk around the vent is failing. It appears that way. This Casita has been in Palm Springs for the past 6 years and is new to us - that kind of heat is pretty rough on things. I'll search the archives to see what folks recommend for removing and resealing (I don't think it's silicone) and see if that does the trick.
thanks!
Jane
2012 Escape 19
Old 06-06-2011, 12:43 PM   #5
Hi, Jane
You might want to take a look at this recent discussion:
How is a vent supposed to be attached to a roof?
Francesca
Old 06-06-2011, 12:47 PM   #6
Thanks, Francesca. I think it's coming in through the little range vent that's on the side of the trailer - above the range is dry, but I will check the thread -- all hints and tips welcome!
Jane
2012 Escape 19
Old 06-06-2011, 12:52 PM   #7
oops!
I thought you meant up top!
If you do remove and reseal, butyl plumber's tape is in my opinion the best sealant to use...
You can buy it by the roll at most RV places and some hardware stores.
Good luck!
Francesca
3/4" x 30' Gray Butyl Tape: Mobile Home Parts Store
Old 06-06-2011, 01:00 PM   #8
Thanks! Do you think I should remove the vent? I was thinking I could just remove the layer of caulk/sealant around the vent and replace that. You sound like you're much more an expert at this than I am so I'd really welcome your advice!
Jane
2012 Escape 19
Old 06-06-2011, 01:55 PM   #9
Well, I can only speak from my own experience- I guess that makes me a little bit of an expert!
My motto seems to be "If a thing is worth doing, it's worth doing TWICE !"- I usually get it right the second time!
My experience with patching leaks without removing the vent/window has been that I'll have to do so eventually anyway... patching with silicones, etc. hasn't worked very well for me.
It's easy enough to remove a vent cover- I think. As I said, I'm not familiar with Casitas- if the cover's plastic and brittled by age/sun there might be a risk of breaking it while removing/replacing.
If it's riveted on, you just drill out the rivets, pry off the cover, clean the old caulk off, put the tape on , and re-rivet the cover back on the trailer.
Francesca
EDIT P.S:
I wouldn't go to all that trouble without making sure that the vent is the leak source...I've run a garden hose over various spots to accomplish this.
Old 06-06-2011, 04:26 PM   #10
LOL! I understand! And, every project requires at least 3 trips to the hardware store too! I'll test the vent with a hose to see if it is the culprit and then inspect very carefully before doing anything. Thanks again!
Jane
2012 Escape 19
Old 06-06-2011, 08:57 PM   #11
If you decide to go ahead and take the vent off, clean it up and paint it with Fusion paint for plastics. It will delay damage to the plastic from UVs. And it's easier to paint with it off, than on the trailer.
Old 06-07-2011, 12:19 PM   #12
Good idea, Donna. Since we don't have rain in the forecast, I have some time to make sure I do this right!
Jane
2012 Escape 19
GONE - Free Range Hood francene Classified Archives 6 09-12-2009 09:23 PM
Range Hood Graeme Problem Solving | Owners Helping Owners 2 07-31-2008 06:48 AM
Range Hood Graeme Problem Solving | Owners Helping Owners 1 05-20-2008 06:02 PM
Range vent hood KamperBob Classified Archives 8 08-30-2007 08:35 AM
Range hood MikeyC Problem Solving | Owners Helping Owners 1 07-31-2007 07:33 AM
