Water filler cover broken - Page 2 - Fiberglass RV
Old 03-08-2013, 11:30 PM   #15
Trailer: '77 Scamp
Okay, are you ready for another stupid questions? My first road trip with the Scamp will be in May. I have Scamp's standard issue water filler on the fresh water tank. So here's the question...how do you know when the tank's full (other than having someone inside the trailer scream "STOP" when it gets to the top? If you overfill, will the water just come up and out the filler, or do you risk springing a leak in the vent (honestly, I haven't looked closely at the tank, I'm assuming it is vented).
Otters is offline   Reply With Quote
Old 03-08-2013, 11:45 PM   #16
Wait for the water to come back up out the filler. Thats what I do. You will see when it starts to fill back into the outside cup area of the filler.
Hint: Dont run the water into the tank to fast or it will will back up even if its not full due to air in the lines. .
Old 03-09-2013, 12:00 AM   #17
Trailer: '77 Scamp
Okay, that I can do Carol. Just a little concerned since I will mostly be a solo camper. Thanks.
Old 03-09-2013, 12:53 AM   #18
Linda so am I and you shouldn't have any problems filling the water on your own. You may want to pick up a water tank filler with a shut off valve. It helps a lot to be able to stick the end of it a bit down the filler and to be able to shut it off if the water starts to back up.
Old 03-09-2013, 08:53 AM   #19
IllAnnoy
Take a look at the tank, there should be a tube which come out at the top of the tank and exits through the floor.
If you over fill the tank, the water run out onto the ground. This tube also acts as a vent to allow quicker filling of the tank.
The stock filler takes water slowly, the one I showed in my previous post pours quickly and much easier.
Old 03-09-2013, 09:12 AM   #20
Perhaps Joy A's solution would work for you?
Lock for Fresh Water Fill - Direct link
Old 03-09-2013, 10:03 AM   #21
Trailer: Fiber Stream
Originally Posted by Janb313 View Post
Attachment 55845
Attachment 55846
Okay, I think I got it.
There is a matching set in this style:
  • Water Tank
  • City Water
  • Cable Hatch
I've seen "Water Tank" commonly available in the RV supply stores in the San Diego area, but "Cable Hatch" is quite rare.
I'm using the set on my Compact Jr. rebuild.
I seem to remember an old thread where a member needed one of them because his Trillium originally came with them and he wanted to maintain the "Look".
Old 03-09-2013, 10:10 AM   #22
Trailer: Bigfoot, Trillium, Scamp 5th Wheel
Spokane Wa. and Las Vegas, Nv.
  • Water Tank
  • City Water
  • Cable Hatch
Where is it? Do you have a link? I've seen locking door fresh/city water but none including cable.
Old 03-09-2013, 10:27 AM   #23
Steve I believe the ones in the original photo may be made by a company called J & C and they do have a cable hatch as well but they dont seem to have a combo hatch that you are looking for or at least in my search I havent seen one.
Old 03-09-2013, 10:31 AM   #24
I found them at the local "Brick & Mortar" version of this:
RV Trailer Supply
Originally Posted by RVTS
This site contains our sale items only.
If you are looking for a special part, e-mail or call us.
These aren't "Locking Door" however...
Old 03-09-2013, 12:11 PM   #25
Trailer: '96 Scamp 5th Wheel
Floyd, Where did you find that one. Does the hose screw in for filling? I found one I thought looked good but forgot to bookmark it! I haven't learned to drill out rivets or put them in but I have a feeling I'm about to!
JanB
The Gypsy Wagon
Janb313 is offline   Reply With Quote
Old 03-09-2013, 01:03 PM   #26
Jan, when looking at your options for filling your fresh water tank you need to look at the ports that say they are gravity feed and not city water - the city water connections look very much the same but you need to screw the hose on to them for filling. The gravity fill ones do not require you to screw the hose on them - so you can fill it just using a portable jug if you need to.
Old 03-09-2013, 01:11 PM   #27
I might go with this one. It locks and it looks like there is plenty of room to drill a hole for a cable attachment.
RV Gravity City Water Tank Fill Dish New Hookup Hatch with Door Lock Marine | eBay
Old 03-09-2013, 01:44 PM   #28
Wonder if you got a plastic plug like the type used on the hot water tanks and put it into the connection you want the cable coming out of and drill a hole in to the middle of it to hold the cable if that might work.
Flush Mount Water Filler Deb & Chuck Commercial Posts and Products 3 05-25-2012 05:31 PM
Where to find plastic cover for water/electric? Panoz77 Problem Solving | Owners Helping Owners 10 01-18-2012 04:11 PM
Water filler and cord access Gary Z Care and Feeding of Molded Fiberglass Trailers 3 03-30-2009 12:50 PM
broken hand water pump cyndi H Problem Solving | Owners Helping Owners 21 10-21-2008 05:58 AM
Bed, tire cover & filler shirley munson Classified Archives 18 06-01-2006 01:57 PM
