Water heater - Fiberglass RV
Old 12-13-2012, 08:42 AM   #1
Trailer: 2015 Escape
Water heater
Ours will operate on electric or gas. Neither setting will make the water hot enough to need cooling for a shower nor will it get hot enough to properly wash dishes. Tried it with both electric and gas turned on and got the same result. Any ideas? I'm waterheaterly challenged. Thanks
Old 12-13-2012, 09:22 AM   #2
Trailer: Class A Motorhome
Did you check the temp adjustment on the water contol valve???? Most will bring water up to about 140 degrees on gas
If you don't have the operating manual for the heater, just google the make and model number, followed by the word "manual", and one will usually appear.
Old 12-13-2012, 04:02 PM   #3
Steve Hammel's Avatar
Trailer: Trillium 4500
I agree with Bob. Additionally, what year is it? Have you checked for sediment?
Old 12-13-2012, 07:12 PM   #4
cpaharley2008's Avatar
It would seem that the propane is not working as the electric should only maintain vs heat up the water, propane would heat it hot stand alone.
Old 12-13-2012, 09:38 PM   #5
Brian B-P's Avatar
... the electric should only maintain vs heat up the water, propane would heat it hot stand alone.
Since we don't even know the model of heater, I see no justification for declaring the electric element incapable of heating water to the desired temperature.
We have a motohome (no, this one's not an egg, but the 6-gallon RV water heater doesn't know that) with an Atwood water heater which delivers very hot water on just the (factory-installed) electric element. Recovery time would be long, but if you don't need more than 6 gallons at a time, that doesn't matter.
Old 12-13-2012, 09:50 PM   #6
mszabo's Avatar
Trailer: U-Haul VT16
The problem is you have a bypass valve installed. The valve is open between the hot and cold line.
Old 12-13-2012, 11:10 PM   #7
Cathi's Avatar
POBox 1267, Denison, Texas
We have a Suburban and it is plenty hot with electric.
Old 12-14-2012, 05:19 AM   #8
Ron F's Avatar
Trailer: Eggcamper 17 ft Electric
Bob, I replaced the original water heater in our Egg with an Atwood 6-gallon combination gas/electric water heater. It heats well on either fuel. It has a mix valve that allows mixing cold water with the heated water to achieve the proper water temperature. If yours has a mix valve, you should be able to adjust the temperature at the tap. If no mix valve, the problem could be a faulty thermostat or as Mike suggests, a bypass valve that is either leaking or partially opened and acting like a mix valve, allowing cold water to mix with the heated water.
Ron
Old 12-14-2012, 04:02 PM   #9
The water heater is in our Kodiak, not our Egg Camper. We've been out a week and it worked ok the first couple of days. Now, with both propane & electric turned on, it barely gets warm enough for a shower with NO cold added. Nowhere near hot enough for washing dishes. Since we're a thousand miles from home, we have an RV tech coming tomorrow.
Old 12-14-2012, 05:28 PM   #10
We have a 2013 17' Coleman that is, essentially, a rebadged Kodiak, with the dual heat water heater and it works fine on either.
Did you try it on LP ONLY? There may be some interconnect issues when trying to use both sources.
Old 12-15-2012, 03:13 PM   #11
My final word on this. The lack of hot water is either due to my stupidity or my forgetfulness. When dewinterizing I didn't close the bypass valve. No LAUGHING!!!
Water Heater???? Crackedegg Modifications, Alterations and Updates 22 10-06-2012 12:00 PM
water heater Sandra Lair Modifications, Alterations and Updates 16 10-09-2009 10:58 AM
Water Heater Q Eric & Tam Problem Solving | Owners Helping Owners 3 06-19-2007 07:00 PM
Hot Water Heater - Rusty Water terryw Problem Solving | Owners Helping Owners 9 07-15-2006 08:33 PM
Water heater pjanits Problem Solving | Owners Helping Owners 4 04-11-2006 01:23 PM
