Water Heater - Fiberglass RV
Old 05-13-2013, 04:50 PM   #1
Trailer: Coachman
Water Heater
I have an older Coachmen with a newer water heater, propane. My pilot light will light but when I turn it to on nothing happens, my pilot light will stay lit and then go out. The hot water heater may be five years old. This was working last weekend. Any suggestions will be appreciated.
Thanks
Randy
randybcollins is offline   Reply With Quote
Old 05-13-2013, 05:06 PM   #2
Joe MacDonald's Avatar
sounds like the thermo-couple that detects the flame isn't getting hot enough to open the main valve, or you have a propane issue. If the propane tank was turned off for a period of time you may have air in you lines which can take time to bleed out while on Pilot
Old 05-13-2013, 07:42 PM   #3
Coachman?
Old 05-13-2013, 08:09 PM   #4
papa-t's Avatar
Glade Valley, North Carolina
Light the stove burners and let stay on high for a few minuites. Then retry.
“I have tried to live my life so that my family would love me and my friends would respect me. The others can do whatever the Hell they please!” —John Wayne
papa-t is offline   Reply With Quote
Old 05-13-2013, 09:07 PM   #5
mszabo's Avatar
Trailer: 1986 Bigfoot FT20
Clean the spider nest out of the burner assembly.
Which will require removing it to do it right.
Old 05-14-2013, 05:59 AM   #6
Trailer: Coachman
Originally Posted by Donna D. View Post
Coachman?
English teacher
Old 05-14-2013, 06:01 AM   #7
Trailer: Coachman
Originally Posted by joe macdonald View Post
sounds like the thermo-couple that detects the flame isn't getting hot enough to open the main valve, or you have a propane issue. If the propane tank was turned off for a period of time you may have air in you lines which can take time to bleed out while on pilot
thanks, ill see if that helps
Old 05-14-2013, 06:02 AM   #8
Trailer: Coachman
Originally Posted by mszabo View Post
clean the spider nest out of the burner assembly.
i did that, it worked last weekend, ill try it again, thanks
Water heater rgrugg Problem Solving | Owners Helping Owners 10 12-15-2012 03:13 PM
Water Heater???? Crackedegg Modifications, Alterations and Updates 22 10-06-2012 12:00 PM
Water Heater.........HELP ! aaronet Problem Solving | Owners Helping Owners 5 06-14-2011 12:26 AM
Water Heater Q Eric & Tam Problem Solving | Owners Helping Owners 3 06-19-2007 07:00 PM
Hot Water Heater - Rusty Water terryw Problem Solving | Owners Helping Owners 9 07-15-2006 08:33 PM
