Water Heater Flame Won't Burn Blue - Fiberglass RV
Old 09-24-2012, 04:10 PM   #1
Cyndi B.'s Avatar
Trailer: 2010 Scamp 5th Wheel/2007 Toyota Tundra/2015 Tundra
Montana
Took the Scamp out for the first time since returning from North Dakota boondocking. Stove top lit fine, had a little trouble with the frig, could not get the water heater flame to burn clean. Used everything in ND just before we moved back.
Cyndi B. is offline   Reply With Quote
Old 09-24-2012, 04:18 PM   #2
Cyndi thats an indication that the burner tube may have an obstruction of some type - could be something as simple as a spider web in it. There is a manual for the Attwood heaters in the Document center here and it has instructions for cleaning out the tube, Its pretty easy - I had to do the one on my water heater once.
Old 09-24-2012, 04:31 PM   #3
Use an air compressor to Blow out the burner tube or use a Pipe Cleaner (The kind of pipe people smoke) to clean it out.
Then if it still does the same thing, adjust the air regulator on the end of the tube where the gas enters.
Old 09-24-2012, 06:46 PM   #4
Cyndi B.'s Avatar
Montana
We will try this. It has been a good year for spiders in Iowa due to the dry weather. Thanks!!!
Heater won't start automatically RickU Problem Solving | Owners Helping Owners 16 09-28-2012 09:49 AM
Glo Warm - Blue Flame/Infrared Heaters kentj Care and Feeding of Molded Fiberglass Trailers 15 02-16-2009 03:45 PM
Open Flame vs Catalytic Heater Loren G. Hedahl Problem Solving | Owners Helping Owners 4 07-29-2008 11:44 PM
Hot Water Heater - Rusty Water terryw Problem Solving | Owners Helping Owners 9 07-15-2006 08:33 PM
Aaarrrgh! Heater Won’t Work Gina D. Problem Solving | Owners Helping Owners 24 12-20-2005 09:15 PM
